NightCrawleR's Project ( phase 1: Engine Build / TT )
Old 11-10-2010, 09:55 AM
  #41
str8dum1
str8dum1's Avatar
thats fine. all depends on what his base is.
62-14 = 48psi base. perfectly fine
52-14 = 38psi base. if the car starts with no problems, even better.
fuel pumps flow more with lower pressure or higher voltage.
You want your base fuel pressure as low as you can without starting issues. That way when you boost, you are still getting good flow from the pump
Originally Posted by midz350
52 psi at WOT!!! Are you sure? that is not good I think!!
My car is 52psi at idle.
Old 11-10-2010, 11:15 AM
  #42
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Originally Posted by nightcrawler_8
now one thing we noticed, while i was tuning . the feul pressure was 52 PSI @ woot... now when am pushing it its 62psi @ woot !!!??
what do you guys think !!???
100 % Normal, You have a one to one fuel press regulator for every psi of boost you will see 1 psi of fuel press increase. You need to be concerned if the fuel press is not increasing with boost .
Sam
Old 11-10-2010, 11:31 AM
  #43
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
the car was tuned as i mentioned earlier, and all was perfect. the car felt sooooooo much powerful and i got even better response that before, it doesnt feel that much laggy ( compared to before the tune, but its still lil laggy ) .. and i asked the tuner to set two maps for me:
  • low boost: without methanol: tuned on 11 psi and was planning to drive it on 8 psi ( A/F set to 10.9-11.2 )
  • highboost: with methanol : 14psi ( A/F 11.7-11.9 )
and got a swtich installed to toggle between the maps.
after driving the car for couple of days, i noticed that the high boost map is showing 10.2 A/F @ woot. ..!!!!! and low boost map is showing 10.8-11.2 A/F ??!!!!
Now as for the inconsistency of the air fuel ratio under boost, this will happen sense you are using the unship witch uses maf Clamping so once you maf reach the clamp setting your tune is working of the fuel press regulator one to one ratio. Note that it only takes 6 psi of boost to reach the max voltage of your stock maf .
Old 11-10-2010, 11:32 AM
  #44
nightcrawler_8
nightcrawler_8's Avatar
Sam
yeah, but the problem is that the feul is acting up. sometimes i get low pressure, sometime i get high pressure. so the tune is getting mixed up.
today, we opened the tank and we found out that the internal feul filter is all glocked and need to be replaced, i guess i will go for the CJM Twin pump
Old 11-10-2010, 11:34 AM
  #45
nightcrawler_8
he is not using the maf.. i have the unichip with the map sensor.
Old 11-10-2010, 11:46 AM
  #46
Sam@GTM
GT Motorsports
Sam@GTM's Avatar
Oh good, Then maybe it is a fuel delivery issue .
Sam
Old 11-10-2010, 02:59 PM
  #47
str8dum1
str8dum1's Avatar
that will be even worse as there is no filter at all on there.
Old 11-10-2010, 09:12 PM
  #48
nightcrawler_8
so what do you guys suggest !!!!
now after cleaning up the filter ( 70% cleaned ) the fuel pressure is dropping too much ..
on idle 52psi
4500 RPM around 60psi
and its keep dropping till 48psi. and i let go the gas. so that i dont risk it.
Old 11-11-2010, 06:37 AM
  #49
str8dum1
str8dum1's Avatar
well i meant if you problems stemmed from dirty tank... but if you cant hold fuel pressure while boosting, your fuel pump is shot or you are making too much HP.
If you are making less than 500whp then a single pump is fine. If you are making over 600whp, then you want to switch to the twin pump.
You'll want to drain your gas tank and clean it thoroughly before adding the twin pumps.
Old 11-11-2010, 09:27 AM
  #50
phunk
CJ Motorsports
phunk's Avatar
the twin pump does have pump pickup filters on it like any typical intank setup... but there was no room to integrate the post pump small micron filter like the OEM pump assembly. An external fuel filter, such as a billet aeromotive 10 micron, should be installed when using our twin pump. Or a pair of OEM filters from misc applications could be used as a less expensive alternative.
Old 11-11-2010, 11:08 AM
  #51
nightcrawler_8
thanks for the info, please pm me price for the Twinpump..
Old 11-11-2010, 11:42 AM
  #52
phunk
CJ Motorsports
phunk's Avatar
pm sent!
Old 01-24-2011, 11:41 PM
  #53
nightcrawler_8
update:
- Twin pump installed and the fuel pressure is just perfect now .. will be doing a tuning session soon.
- Increased the RPM to 7500 ( thaks Sam@GTM )
- installed AEM water/Meth
https://my350z.com/forum/forced-indu...tallation.html
so, i was thinking where to install the AEM methanol kit since the bottle i have is quite big and have the full trunk utilized for the sound system ..
so i found the answer .. dont think that anyone did that before ( as far as i know )
Bye bye BOSE
tataaaaa
intercooler sprayer.. i am using the snow performance bottle for that.
just thought of sharing it so that ppl might have new options.
Old 01-24-2011, 11:55 PM
  #54
phunk
CJ Motorsports
phunk's Avatar
twin pump
Old 01-25-2011, 04:27 AM
  #55
nightcrawler_8
twin pump
ofcoruse,
CJM FTW
the pressure is very steady now.
check the below video.
http://www.youtube.com/watch?v=M2Z1F_fIiwM
Old 01-25-2011, 06:49 AM
  #56
phunk
CJ Motorsports
phunk's Avatar
very nice
Old 01-25-2011, 07:14 AM
  #57
Get Your Wheels
Vendor - Former Vendor
Get Your Wheels's Avatar
Very nice build on the motor!
Old 07-04-2011, 12:30 AM
  #58
nightcrawler_8
Old 07-04-2011, 12:31 AM
  #59
nightcrawler_8
Update....
did want to post updates till the project is over and the build is finished.
below is the final dyno sheet.
STD 5, with 1 smooting correction only.
0.9 HP above 600.. lol
Old 07-04-2011, 01:15 PM
  #60
binder
binder's Avatar
well... nos is out of the equation at all..
what do you think would cause the lag then !!!.. i cannot find any justification to that..
a friend of mine drove the car and he said " WOW. it feels like a supra with T88 turbo.." a very noticable lag but once it gets into boost. its just a rocket..
driver error on gear selection
why do people on this forum want to race at 2800 rpms? just downshift
*also verify there isn't a boost leak but from the sound of it this is normal spool for a gt30 sized turbo setup
Quick Reply: NightCrawleR's Project ( phase 1: Engine Build / TT )
