Hard hot start
Old Oct 6, 2010 | 12:40 PM
shakuya88's Avatar
shakuya88
Default Hard hot start
Hey everyone!
So I have searched and searched and now out of ideas. So here it goes. 2004.5 g35 with GTM TT stage 1 6 psi Osiris tuned. Cold start is fine and strong. The issue is hot start. It will just keep cranking and cranking. It only happens when I've actually driven somewhere. So coolant and oil up to temp. Doesn't do it if I just get the coolant up to temp. I have absolutely no clue what could be causing it. The iat and ect are both normal. Checked with cipher. Any ideas would be great! Thanks everyone!
Old Oct 6, 2010 | 12:44 PM
DavesZ#3's Avatar
DavesZ#3
Is it cranking slow or at the normal speed? Weak battery could cause it to turn over slower than normal and be difficult to start. Starter going bad could also be a problem. When hot, the internal resistance rises making it harder to get the starter to run at normal speed, that make it hard to start the engine.
Old Oct 6, 2010 | 01:15 PM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Send me your map and I will fix it for you free of charge. failsafeperformance@yahoo.com
Old Oct 6, 2010 | 01:17 PM
shakuya88's Avatar
shakuya88
It's cranking at normal speed.
Old Oct 6, 2010 | 01:28 PM
shakuya88's Avatar
shakuya88
Thanks! I'll send it to you as soon as I'm home. What do you think may be wrong with it?
Old Oct 6, 2010 | 01:50 PM
Chris@FsP's Avatar
Chris@FsP
The hot start tables most likely need to be adjusted
Old Oct 6, 2010 | 01:51 PM
djamps's Avatar
djamps
It takes time to work these issues out (or to do the tune right from the beginning) but many tuners will try to tell you this is 'normal'. In a nutshell, it's all in the tune.
Old Oct 6, 2010 | 01:52 PM
djamps's Avatar
djamps
Osiris doesn't have a 'hot start' or 'cold start' map. Cranking enrichment adjustments might help a little. Hot start / cold start issues with Osiris are usually signs of a deeper problem in the tune such as injector scaling or MAF calibration. I ended up having to do a complete retune from the ground up to get rid of my starting issues.
Old Oct 6, 2010 | 01:57 PM
cdoxp800's Avatar
cdoxp800
I had the same issue. Never got it resolved. I just gave up and I am back to N/a.
Old Oct 6, 2010 | 02:03 PM
Chris@FsP's Avatar
Chris@FsP
Originally Posted by djamps
Osiris doesn't have a 'hot start' or 'cold start' map. Cranking enrichment adjustments might help, but hot start / cold start issues with Osiris are usually signs of a deeper problem in the tune such as injector scaling or MAF calibration.
I know very well what Osiris offers; I've tuned a couple of them. I just misspoke when I said 'tables'.
Old Oct 10, 2010 | 10:37 PM
winNvegas's Avatar
winNvegas
I have the same problem. Dont know if this is true but a few people have told me that because the injectors are bigger, the engine get too much gas on the start up and is difficult to start. Therefore after you let the car sit, some of the gas dries out and is then able to start easier.
Old Oct 11, 2010 | 05:08 AM
djamps's Avatar
djamps
At the sake of repeating myself: it's all in the tune. If you throw in bigger injectors and don't make the right compensations in the right areas for the added flow, you will have starting issues.
Old Jan 30, 2012 | 01:54 PM
Ztouring04's Avatar
Ztouring04
I know this is old. But I'm having similar issues. Had it looked at! Will a full fuel system fix this? Help
Old Jan 30, 2012 | 02:09 PM
unvmyg35's Avatar
unvmyg35
I had hot start issue with my ID 725CC injectors on my vortech system. After break-in period I took it back to my tuner and the issue was fixed. Tuned with uprev! Your tuner should be able to fix it.
Old Jan 30, 2012 | 02:41 PM
MM'08_350Z's Avatar
I have ID 725cc injectors on my N/A set up I also had a lot of problems with hot starts. I took it to Uprev and had the car retuned by a pro tuner and problem gone.
Old Jan 30, 2012 | 05:41 PM
Ztouring04's Avatar
Ztouring04
i had the car tuned twice and same problem.....i have 600cc injectors and walbro 255... frustrating!
Old Jan 30, 2012 | 06:26 PM
unvmyg35's Avatar
unvmyg35
I was going to install a set of DW 600cc that I bought new from a member but my tuner went against it. He said he had trouble getting the 600 hot start issue fixed. I sold the dw and went with his recommendation on ID 725cc.
Old Jan 30, 2012 | 06:30 PM
Ztouring04's Avatar
Ztouring04
^ thanks man thats pretty much what my tuner said.....time to hit the drawing board again!
Old Jan 31, 2012 | 12:25 AM
=Cerberus='s Avatar
=Cerberus=
I was just talking about this same issue, and found it convenient that this thread is bumped. The shop what is doing my work installed ID1000s, which I think are to large, and will cause a hot start issue.
My Uprev pro-tuner is working on a G35 this Saturday with a hot start issue, and has informed me that with the latest update, hot start tables have been either added, or tweaked to the software.
Old Jan 31, 2012 | 02:05 AM
0jiggy0's Avatar
0jiggy0
Im not answering you because 2 people repeatedly answered your question 2 years ago.
