AEM Wideband 02 A/F UEGO Gauge, VQ35HR
Old Oct 10, 2010 | 10:03 AM
nismofreak1208's Avatar
nismofreak1208
Default AEM Wideband 02 A/F UEGO Gauge, VQ35HR
This is mainly directed to those with the VQ35HR, I have researched and would like to purchase the AEM UEGO Gauge but since it only comes with a single sensor, how can this be used with our setups that utilize dual 02 sensors? I've seen a couple members on this forum who stated they are running the AEM a/f gauge but I would like to know how before I go ahead and make the purchase. Any input would be appreciated.
*EDIT* Since both motor versions came with dual 02 sensors, this is then directed to all
Old Oct 10, 2010 | 10:18 AM
350z 6spd's Avatar
350z 6spd
Most people only run a single wideband on both the DE and HR. The DE has dual O2 sensors as well.
I believe most usually install it on the driver's side as that is the side that tends to run leaner (although very slightly and almost unnoticeable at WOT). That's where I have mine.
Old Oct 10, 2010 | 11:18 AM
xzotklr's Avatar
xzotklr
Why not run a dual wideband set-up?? You would be able to immediately spot a significant difference between banks.
Old Oct 10, 2010 | 12:28 PM
nismofreak1208
so just run two AEM gauges then for each 02 sensor?
Old Oct 10, 2010 | 01:06 PM
str8dum1's Avatar
str8dum1
you are not replacing your stock O2 sensors, so you only need 1 aftermarket sensor. you can always have 2 but thats mostly overkill.
Do you have an EMS that does bank specific tuning? If not, then it doesnt matter if you have 1 or 2 widebands anyhow.
Old Oct 10, 2010 | 01:23 PM
nismofreak1208
no, the tuning will be done with osiris
Old Oct 10, 2010 | 01:24 PM
midz350's Avatar
midz350
Mine is in the driver's side. HR here.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
