Anticipation...
Old Nov 16, 2010 | 07:36 PM
  #41
jtgli's Avatar
jtgli
Originally Posted by Jokestrap
Dude, first is useless, second is totally out of control and third is barely controllable at 15.4psi. Why in the world would you want 670+rwtq? That's not even streetable with any kind of pressure on the gas.
Why would I want 670wtq? Who wouldn't is the question? As far as traction goes, with that high setting yes I couldn't plant the power on normal summer tires so I've switched to smaller and wider wheels with Mickey Thompson street radials and problems solved. I was simply stating that for $30-35k you SHOULD be making a lot more than what you are.
But I can see from you eyes also. Again I'm not trying to be a d!ck about it, was simply stating my opinon. Congrats on the build though.
Old Nov 16, 2010 | 07:47 PM
  #42
Jokestrap's Avatar
Jokestrap
Oh I hear you and understand completely... and agree. However, I simply want a road course car that will withstand the test of time, run clean, and make ( the only one I really care about) me happy for time to come. My build and money spent could certainly prove to have more impressive numbers but that is not my deal. Thanks for commenting bro.
Old Nov 18, 2010 | 02:42 PM
  #43
Sylvan Lake V35's Avatar
Sylvan Lake V35
Anyone in my position with my build can turn up the boost and let it rock, race gas, whatever. Dynoqueen is not my thing. Sorry to disappoint you but that is not what I am in this for. I want to get back on the course with something that can kick a$$ and won't give me a hard time.
I guess if you would have mentioned you wanted a reliable track car with 550whp no one would have questioned you high cost/hp as most road course cars are built that way. I bet that car will a blast to drive on road courses, I am sure you will enjoy it!!!
Old Nov 19, 2010 | 06:28 AM
  #44
str8dum1's Avatar
str8dum1
+1, just seemed like alot of hype for a low/average whp.
but all understand excitement
You can imagine, with 30-35k in just parts & EMS, it is a pretty serious build. Everything but sleeved on the engine really and world class electronics all the way...
Old Nov 21, 2010 | 08:33 AM
  #45
Jokestrap's Avatar
Jokestrap
Sam set the race gas map at 17.8psi. I'll have to throw some in there and take it to the dyno just to see where it ends up. Then I'll post that up...
Old Nov 21, 2010 | 02:36 PM
  #46
nyqueenz's Avatar
nyqueenz
Originally Posted by seymore4
Its at GTM... It's gonna take another 6 months
lol, cant rush prefection thou..
Old Nov 21, 2010 | 05:45 PM
  #47
seymore4's Avatar
seymore4
Professional
Glad the OP got his baby back thats something to be celebrated no matter the final power #
Old Nov 22, 2010 | 06:41 AM
  #48
XBS's Avatar
XBS
Veteran
Keep in mind when you fill up with race fuel you still have pump gas in the tank and it will lower the effective octane rating, if possible run the car as low on pump as possible then fill up with 100+ (run VP 109 if you can get it)
Good luck!
Old Nov 22, 2010 | 08:04 AM
  #49
Alberto's Avatar
Alberto
Cranky FI Owner
No offense OP, but this is another example of a shop selling parts/work and/or a Z owner not doing research.
You dont need any headwork (other than cams), you could have used that money for other things and made much more power if you wanted to. Head work for the level of power you seem to want is not needed at all. Its as silly as a flat chested b!tch trying to wear a D cup bra, you would see her and be like "WTF?" ...my reaction is the same here.
Why do headwork when 95% of builds dont need it, and then not even have a fuel system to support making big power? And then say "who needs 670ft/lbs?"
And are you saying you have a race gas tune but no numbers?
Makes no sense to me, but as long as you're happy...
Old Nov 22, 2010 | 09:39 AM
  #50
str8dum1's Avatar
str8dum1
he already had all that stuff from the original build from SGP. but based on threads like this https://my350z.com/forum/forced-indu...a-scammer.html
you are prolly spot on with vendor oversell.
None of the motor is from GTM. SGP engine and work previously. Get it?.
joeking1978
Videos
Sep 28, 2004 09:36 PM
