Going for inspection.. need help disabling the SC
Old Nov 5, 2010 | 03:21 AM
maXmood's Avatar
maXmood
Under Boost!
Default Going for inspection.. need help disabling the SC
It's time of the year, i need to take the car for inspection.
I'm running vortech sc, i need to disable it. do i just remove the cog belt?
thanks
Old Nov 5, 2010 | 03:37 AM
midz350's Avatar
midz350
Just pay a guy some $$$ and then even you don't have to take the car out of the garage
Old Nov 5, 2010 | 04:57 AM
maXmood's Avatar
maXmood
Under Boost!
^i can't find that guy!!!
Old Nov 5, 2010 | 05:05 AM
twitch579's Avatar
twitch579
Move to Florida! We dont have these problems.
Old Nov 5, 2010 | 05:23 AM
laxplaya1385's Avatar
laxplaya1385
Pardon my ignorance, but why do you have to disable the SC for inspection?
Old Nov 5, 2010 | 05:29 AM
Vas_Z33's Avatar
Vas_Z33
I dont see why you have to disable the SC.. its not like it will pass you or throw codes when its running... Ive passed inspection with the SC still in the car, as long as there are no codes in the OBD you will pass just fine.
Old Nov 5, 2010 | 05:41 AM
tonyzS/C03's Avatar
tonyzS/C03
yeah i passed all my inspections with my Vortech...
maXmood's Avatar
maXmood
Under Boost!
we're in two different areas of the world.. i'm on the other side to be precise.
no modifications are allowed on cars here. not even stickers/vinyl. so yeah, i have do disable that SC to pass inspection.
Old Nov 5, 2010 | 05:48 AM
tonyzS/C03's Avatar
tonyzS/C03
ahhhh well then... yes just pull of the cog belt and your good.
Old Nov 5, 2010 | 05:51 AM
maXmood's Avatar
maXmood
Under Boost!
^what happens if i go WOT?
Old Nov 5, 2010 | 06:09 AM
tonyzS/C03's Avatar
tonyzS/C03
you should be ok, if anything you'll run pig rich because you've removed air from the mix, which is better than running lean... All the same i've stay out of it till you put the belt back on.
Old Nov 5, 2010 | 06:44 AM
Erdem's Avatar
Erdem
can't u switch map to "driving without SC"?
Old Nov 5, 2010 | 06:47 AM
maXmood's Avatar
maXmood
Under Boost!
i don't have a map on haltech for "no SC"
Old Nov 5, 2010 | 06:56 AM
Erdem's Avatar
Erdem
sorry I forgot u went away from Osiris?
does the Haltech provide a map switch system btw?
Old Nov 5, 2010 | 07:04 AM
Erdem's Avatar
Erdem
when I go to inspection here in Denmark.. I'm going to remove the blower, the plate Intercooler and all piping..
so removing the belt only is a easy thing
Old Nov 5, 2010 | 08:52 AM
- bigc -'s Avatar
- bigc -
is there a visual inspection? if so, removing the cog belt isn't going to make the blower disappear
Old Nov 5, 2010 | 08:59 AM
GreenGoblin's Avatar
GreenGoblin
^ that is when you do the.... hey look at that plane and close the hood.
Old Nov 5, 2010 | 09:13 AM
tylerxfire's Avatar
tylerxfire
i passed inspection no problems, vortech, no cats etc...
removing the cog belt is not going to take the supercharger away..dont know what to tell u...also if u take the cog belt off and run the car its gonna run rich just baby it and dont go wot..y would u need to go wot..just drive the car and remove the belt right before u get to the shop if thats what u are gonna do..takes 2 mns.. but really seems pointless, i mean the haltech and all other supporting mods are still there including the whole kit on the car
Old Nov 5, 2010 | 10:25 AM
str8dum1's Avatar
str8dum1
why in the world will the car run rich?
You will only be in vacuum, so it will be no different than running with the SC out of boost.
Old Nov 5, 2010 | 10:40 AM
maXmood's Avatar
maXmood
Under Boost!
Visual and sound/noise inspection.. but since the car is 2006, they won't bother looking under the hood unless they hear the whisle from the BPV, because they inspect the sound/noise of the exhaust as well, so i'll have to rev a bit.
removing the cog belt would disable the BPV as well, isn't it?
