Cog Belt for Vortech 400% Stronger
Old Oct 20, 2013 | 08:08 AM
  #41
meanz's Avatar
meanz
Originally Posted by OldManZ350
here is a better price.......
Best Strongest Best on the market.......
8MGT-608-21
Gates Part # 9270-1071
Poly Chain GT Carbon Belts - 8M Short Length
0.25 pounds
Price - $26.40 US
https://shop.limct.com/?page=shop/br...3b95961c481de&
Hey oldman, my setup is on the de bracket. Im about to place my order for two of these belts. Just want to make sure this is what I need. Thanks
Old Oct 20, 2013 | 11:02 AM
  #42
OldManZ350's Avatar
OldManZ350
THat's It!!!!!
Old Oct 20, 2013 | 03:05 PM
  #43
meanz's Avatar
meanz
Thanks, just picked up 2 of these..
Old Oct 22, 2013 | 09:32 AM
  #44
meanz's Avatar
meanz
Just wanted to say how fast their shipping was... Ordered Sunday night and today I go an email with a tracking number via FedEx saying the belts will be here today!
Old Feb 22, 2014 | 05:52 PM
  #45
mazymus's Avatar
mazymus
Gates 8MGT-608-21 Polychain GT Carbon Belt 8mm Pitch
http://www.vbeltsupply.com/8mmpolychainshort.html
This is the Strongest Belt you can get in this size.
I'm bringing this old thread up..
I have the V3 Vortech on my 03 Z. My Cog belt ripped again to shreds (second time..) I think this is happening once every two years. Must be too tight or something..
Anyways, last time I ordered from Vortech and took way too long to get it. Plus it was kinda expensive.
What has your experience been with the LIMCT one?
is this what I need to order??
https://shop.limct.com/?page=shop/fl...duct_id=19197&
This is what I ordered from Vortech last time:
http://www.vortechsuperchargers.com/...n.php?pvk=1556
Thanks all
Old Feb 22, 2014 | 08:30 PM
  #46
mazymus's Avatar
mazymus
nvm, just ordered it here..
Gates 600-8MGT-20 GT 2 PowerGrip Belt, 8mm Pitch, 20mm Width, 75 Teeth, 23.62" Pitch Length: Amazon.com: Industrial & Scientific Gates 600-8MGT-20 GT 2 PowerGrip Belt, 8mm Pitch, 20mm Width, 75 Teeth, 23.62" Pitch Length: Amazon.com: Industrial & Scientific
Old Feb 25, 2014 | 11:47 AM
  #47
str8dum1's Avatar
str8dum1
cog belts will only break if they are too tight.....
Old May 15, 2015 | 04:55 PM
  #48
philthethrill's Avatar
philthethrill
bumping this up, i need help! i have rev up with a 28 tooth cog pulley on the charger. i went from 34 32 to 34 28 now the belt is to big . i need something smaller then the stock70 tooth belt need help dyno day is tues
Old May 15, 2015 | 05:21 PM
  #49
OldManZ350's Avatar
OldManZ350
The next size smaller belt is a 60T, way to small.......
Their is a Vortech Guy on here that did a 34/28 cog on a Revup. He made a small plate with a small diameter idler that mounted to the back side of the blower.
He had a Yellow 350Z, anybody remember his name?
Old May 15, 2015 | 05:28 PM
  #50
OldManZ350's Avatar
OldManZ350
I found this belt. This is a 68T, it might work for you.
8MGT-544-21 Poly Chain Belt
http://www.vbeltsupply.com/poly-chai...hain-belt.html
Attached Thumbnails Cog Belt for Vortech 400% Stronger-screen-shot-2015-05-15-at-9.26.21-pm.png
Old May 15, 2015 | 05:33 PM
  #51
philthethrill
thanks ill double check the belt size i know its a 20mm wide 8 mm pitch
Old May 15, 2015 | 05:36 PM
  #52
OldManZ350's Avatar
OldManZ350
This is the right belt, just may still be to long for you. But its closer for sure. ( it's 21mm wide 8 mm pitch )
Old May 15, 2015 | 05:40 PM
  #53
philthethrill
mines 20mm wide.. will that matter
Old May 15, 2015 | 05:42 PM
  #54
OldManZ350's Avatar
OldManZ350
NO! it's just 1 mm (.03937")
It will be fine.
Old May 15, 2015 | 05:43 PM
  #55
philthethrill
that 60 tooth might work that other belt was huge. i mean the tensioner was so tight it was touching the cog pulley
Old May 15, 2015 | 05:49 PM
  #56
philthethrill
here is the pic
Old May 18, 2015 | 11:13 AM
  #57
350z006's Avatar
350z006
I can confirm that I use the belt OldmanZ350 recommended for my 34/28 Revup Vortech setup....
Old May 20, 2015 | 08:23 PM
  #58
philthethrill
the 68 tooth?
Old May 21, 2015 | 12:02 PM
  #59
350z006's Avatar
350z006
Yup
the 68 tooth?
Old May 27, 2015 | 07:37 AM
  #60
the3kgt2's Avatar
the3kgt2
I tore up another cog belt. It definitely wasn't too tight. This is the 2nd cog destroyed in a year. I heard it skip a tooth right when I hit 7,000rpm and 12psi. My tuner is thinking it's tearing up because of heat so we might put an air vent in the fender liner to escape some heat out. We got a new cog from Vortech (apparently they upgraded their cog belts recently) but I just ordered 8MGT-608-21 in case it happens again.
