Wheel Hop
Old Jan 31, 2011 | 09:53 AM
ashtrojan2008's Avatar
ashtrojan2008
Originally Posted by rh_334
considering no launch, starting from 1500rpm id say thats about right
sounds about right to me. back when i was 482whp(dynojet)461whp(DD) i was trapping 122-124 with stock wheels and tires, so i'd say the weight of the g and easy launches accounts for those couple miles per hour.
by the way I used to wheel hop 2nd gear real bad. Haven't been to the track with my new tires but they don't hop on the street.
Old Jan 31, 2011 | 10:04 AM
rh_334's Avatar
rh_334
Originally Posted by thatv35guy
Are you finishing in 4th gear? I think in an 6MT 03/04 G/Z 4th gear should take you to 117 mph at 6600 rpm (with factory size tire)
yea 4th gear, like i said i hit the limiter as i cross with taller rear tires and a 7k limiter
Old Jan 31, 2011 | 10:21 AM
Nexx's Avatar
Nexx
listen to Z-Ya, the dude knows his stuff.
Old Jan 31, 2011 | 10:25 AM
go-fast's Avatar
go-fast
Both front and rear are all the way stiff, ill try to adjust the front soft next time, and i hope the Injected Brace helps, but i bought it more as an insurance policy to keep from leaving that diff behind when if the stud breaks again
you answered your own question in this post,if the rears are all the way stiff you have too much compression and are bouncing the tires off the track.leave the fronts stiff and back off the rears to a softer setting.like alberto said 25#s in the rear will take some of the shock out as well.
people always think wheel hop is from too soft (it is sometimes)but usually it's too stiff of a compression setting in the rear and you are literally bouncing the rear tires off the track,once you bounce it just grows as you stay in it.
Old Jan 31, 2011 | 10:34 AM
rh_334's Avatar
rh_334
It did the same thing on the OE Shocks, thats why i stiffened them, i have the softest rear springs available, I thought the rear was way to soft, so i bought the Konis and still have hop
Old Jan 31, 2011 | 10:47 AM
go-fast's Avatar
go-fast
research rebound and compression (not on this site) and you will understand.....you need to soften compression on the rear
Old Jan 31, 2011 | 10:57 AM
rh_334's Avatar
rh_334
Being a Junior in Mechanical Engineering i understand rebound and compression, which that may still be the problem, but i know of G/Zs with stock suspension with the same problems and the same for Gs with stiff coils
Old Jan 31, 2011 | 11:27 AM
go-fast's Avatar
go-fast
apparently you don't understand how it's applied to drag racing,thats why i'm telling you that you are shocking the tires,soften compression and the rear will squat.....squat is good.....set your coil over about halfway and set your compression to about 30% and rebound to about 80%
now let's recap:
drag race..........
medium/soft spring middle setting
compression soft
rebound medium/stiff
stock struts sucks but are usually better then coil-overs cause idiots don't know how to adjust them.They adjust them "to look cool" and set the car up for drift unwittingly.
g luck
Old Jan 31, 2011 | 02:41 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Just a little info that might help...Tokico rec a soft rear setting for drag racing with there D-specs.
Old Jan 31, 2011 | 03:17 PM
ashtrojan2008
Awesome, I'm also a junior in mechanical engineering. Louisiana Tech University.
Ross
Old Jan 31, 2011 | 09:35 PM
drivessidewayz's Avatar
drivessidewayz
You are talking about the rear bushing in singular form...did you only replace the very back one or did you replace all 5?
Old Feb 1, 2011 | 04:38 AM
RandomHer0's Avatar
RandomHer0
Thats what I was wondering. Did you replace them on the diff "ears"?
Old Feb 1, 2011 | 04:48 AM
rh_334's Avatar
rh_334
Yes i just replaced the rear, at the time i was NA and wasn't planning on dragging the car much and the rear one was the only one busted. So i guess the front ones being soft could still be allowing hop
I didn't think about that...
Old Feb 1, 2011 | 04:50 AM
RandomHer0's Avatar
RandomHer0
I think we just found your issue sir.
rh_334's Avatar
rh_334
Ross
I goto Auburn University
War Eagle!
Old Feb 1, 2011 | 04:51 AM
rh_334's Avatar
rh_334
yep, those are now next on the list. Now just have to findout if i can buy just those or if i have to get them made.
Old Feb 1, 2011 | 04:54 AM
RandomHer0's Avatar
RandomHer0
Considering no one sells them separately anymore. You may have to get them made. I believe JasonZ-YA did.
Im sure he'll chime in.
Old Feb 1, 2011 | 05:08 AM
  #38
rh_334's Avatar
rh_334
Looks like he used SPL https://my350z.com/forum/engine-driv...mp-either.html
I believe this is also why i keep snapping the rear stud, since the front is moving. So lesson learned DO NOT REPLACE JUST THE REAR MOUNT
Old Feb 1, 2011 | 05:23 AM
  #39
RandomHer0's Avatar
RandomHer0
I bet he took measurements prior
In the past SPL would sell the diff/subframe bushings separately. Not anymore. I assume for this reason.
Old Feb 1, 2011 | 06:20 AM
  #40
tig488's Avatar
tig488
i had to put my stock rear setup back on for the same reason. my stockers were softer than the softest setting on my teins.
