Dynosty tunes Momentum GT35R Turbo 350Z to 516whp! Pics
Old Feb 25, 2011 | 12:57 PM
  #41
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Nicely done! These kits are breathing new life into the 350Z...love the power curve.
Old Feb 25, 2011 | 02:04 PM
  #42
GoJira33's Avatar
GoJira33
loving the rinkle paint
Old Feb 25, 2011 | 03:02 PM
  #43
rcdash's Avatar
rcdash
On par with twin GT28s for sure. I'm jealous.
Old Feb 26, 2011 | 09:39 PM
  #44
midz350's Avatar
midz350
No, not really.
Impressive kit and numbers
GL.
Old Feb 27, 2011 | 07:52 AM
  #45
binder's Avatar
binder
what's the info on the exhaust system used? single 3"
Old Feb 27, 2011 | 08:23 AM
  #46
rcdash's Avatar
rcdash
Originally Posted by midz350
No, not really.
GL.
LOL. You're right, the top end is even better and the d@mn turbo is accessible.
Old Feb 27, 2011 | 10:55 AM
  #47
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
impressive at 15 psi. afrs seem like they are around 12.0 if im not mistaken? do you guys have the iat data for that run also?
Old Feb 28, 2011 | 07:15 AM
  #48
DéDé's Avatar
DéDé
Originally Posted by bryan@momentum
ok folks a few minor set backs but nothing major, without further ado, the dyno jet numbers. Weather this morning was 62 degrees, 42% humidity, and 30.xx baro. 93 octane pump gas from the Hess station next door.
With 15 PSI boost?
Old Feb 28, 2011 | 09:31 AM
  #49
DéDé's Avatar
DéDé
Yes DeDe ~15PSI
It's unbelievable or I change the psi to bar incorrect. With stock exhaust and intake?
Old Feb 28, 2011 | 12:13 PM
  #50
binder's Avatar
binder
This was our dual exit, 3" split into dual 2.25"s
good, that's what i'm running so i was just curious if dual 2.25's would be ok. I know mathematically it is more surface area but sometimes things are weird on cars when it applies to physics.
Old Mar 1, 2011 | 07:45 AM
  #51
DéDé's Avatar
DéDé
14.93 psi =[list]
[*] 1.03 bars
Thanks, I also calculated 1 bar but I still dont understand something. Anyway, you made awesome work!
Old Mar 2, 2011 | 04:25 PM
  #52
rcdash's Avatar
rcdash
Bryan, do you have a compressor map for this specific turbo?
Old Mar 3, 2011 | 08:35 AM
  #53
rcdash's Avatar
rcdash
Thank you Bryan. The kit as a whole must be very efficient to be making the power that it is given that airflow spec. Kudos.
Old Mar 3, 2011 | 09:54 AM
  #54
Dynosty's Avatar
Dynosty
Yes sir, I'm hoping Hal can chime in here. Haltech was reading all of that.
AIT starts around 72degF and ends +25degF at ~97degF peak, 7000rpm, 15psi boost. Not bad. AFR is tuned sub-12 throughout.
Old Mar 3, 2011 | 11:04 AM
  #55
binder's Avatar
binder
on the first run or after it's been on the dyno for 2 hours?
Old Mar 3, 2011 | 11:29 AM
  #56
Boosted Performance's Avatar
Boosted Performance
That is on par with what Vas logged on 14psi with that 6" core FMIC, going from 1st throught top of 4th gear on the street.
Old Mar 3, 2011 | 12:01 PM
  #57
binder's Avatar
binder
not to thread jack but yesterday on my hurt motor mine was ambient at 59* and after doing a pull through 2 gears then another one shortly after i only went up to 86*. 17psi boost with a 6" tall core.
Attached Thumbnails Dynosty tunes Momentum GT35R Turbo 350Z to 516whp! Pics-boost.jpg
Old Mar 4, 2011 | 07:53 AM
  #58
rh_334's Avatar
rh_334
You can't accurately compare AIT increases Dyno vs Street...
Old Mar 4, 2011 | 08:13 AM
  #59
Boosted Performance
I am aware of that, that is the feedback I have.
Old Mar 4, 2011 | 07:15 PM
  #60
binder's Avatar
binder
you can't accurately compare AIT from the first pull on a cold engine to an engine that has ran on the dyno for 4 hours and is so heat soaked that you can't touch the plenum. So there is no accurate way to compare anything when it comes to ait's.
