Any interest in a SS catch can?
I need one too, this is going to be vented to the atmosphere right?
Currently i have one hose coming off my pvc, one off the back of the valve cover and a breather filter for each of the middle valve cover ports that are usually bridged together all dumping straight to the ground. This would help keep my engine bay and underbody alot cleaner !
Vendor - Former Vendor
The plate does not go all the way to the bottom, nor does it need to. The plate has to be there between the inlets/outlets. As the vapour goes in, it hits the "wall" or baffle, and runs off/dripps to the bottom where it accumulates. The two holes are there just in case one forgets to empty it for a long time. The air can still move within the can even with it 3/4 full.
To the other questin, yes it will be vented via breather on top.
Since it looks like there is enough interest, I will start working on 10 units right away. When they are ready, this thread will get bumped, and we can go on from there.
Found a proper drain valve for this as well, it has a 3/8" npt NPT thread, with a quick twist for opening/closing. Just run the hose down from it. I hear that many run the drain back to the oil pan, so that may be an option for those that bought the BP ST kit. There is a free port on the oil pan, so you don't have to worry about draining the oil in to a container.
Looks Awesome!
Main concerns to me are:
- Mounting location (Due to being supercharged)
- A Version without the external venting/breather filter? (This is classed as an EPA breach where i live)
The complete kit with hoses and AN fittings are an awesome idea though!!
Maybe offering a blacked out version would be open for consideration.
Thanks.
National Z Club President
I cant see the pictures since I am at work but I know how your work is and I see the posts soo I am sure this is beautiful
If someone can tell me where I need to install this to work best on my JWT kit so I can do this as a DIY then I am in for one instead of paying my shop to install a catch can and making lines/fittings to make it work.
Does anyone know if the lines and all that change depending on what turbo kit you have??
I guess it would depend on how you want to run your lines. I have a line coming from the PCV on the passengers valve cover and a line from the back of the drivers valve cover going to my current can then the outlet goes to one of my turbo intake piping. Sasha's can has bungs welded on it so you could use whatever barb/connector size you wanted.
drivers hose to catch can and pcv to catch can. I'm running mine like that straight to the catch can. Pretty simple. it will work just fine on your car. The only cars that can't use that front mounting area is the supercharged vehicles with a plate on the timing cover.
I'll have install pics here once i receive it so everyone can see it installed on a DE motor. Sasha will probably include pics of it mounted on his rev-up.
There is an outlet that comes our of the backside of the driver's side valve cover ~5/8" i think. For some pre-fabbed turbo systems i.e. greddy, this pipe is fed back into the intake pipe on that turbo...actually, i think that hose goes back into the stock intake tube as well.
ok! I know exactly what you guys are talking about. So this then should be the standard length hoses sasha is using and I can just bolt this right up then?!
Id rather do this then pay for time for the shop to do something so simple.
What are the best connectors to use to avoid leaks or anything?? A.N? I have all A.N lines/fittings on my turbo kit already but I have never done an initial install on them. I am assuming I need a type of adapter??
a catch can install is definitely a DIY. We'll have to wait and see what Sasha's find product/options will be. I'm sure he'll chime in when he gets more of the specifics worked out. I can't wait!
there isnt a ton of info on install or placements that I have read before. Thanks for the advice guys!
This will be very much a DIY job. Just have to get some time to finish the original, and see what would work best. I have to consider all the other turbo kits out there when it comes to location. I always forger that other turbo kits run a lot of stuff in the engine bay, and that it can get crowded. This is the main reason I built the kit I did...but that is a whole different topic.
