maxed out gt 28's
Old May 10, 2011 | 08:07 PM
ace32x's Avatar
ace32x
Default maxed out gt 28's
just curious to see/hear from those who have maxed these out with ur set up and if at all possible a graph . debating keeping mine or upgrading to 30's/35's
Old May 10, 2011 | 08:48 PM
midz350's Avatar
midz350
I saw someone max out one GT28S (RS non ball bearing made by tial sport) .60a/r cold
.64a/r T25 internal wastegate, it did 359WHP 350ft/lbs@27psi straight C16 on a VW 1.8L.
P.S. That is smaller than what GTM use in the STG2.
Old May 10, 2011 | 09:29 PM
abushong504's Avatar
abushong504
Twin gt28's like what comes with the APS basic kit I think maxes out a little over 500 on a dd dyno. That's fully built engine, fuel system, haltech, etc.
Old May 10, 2011 | 09:42 PM
midz350's Avatar
midz350
The GT28RS's with .86 A/R are pretty similar in size to the TD05H-G18's Greddy uses in their kit, and I have seen them break the 700whp!!
Old May 10, 2011 | 09:45 PM
midz350's Avatar
midz350
I will try to max mine out hopefully in a month. (or max out the fuel sys first)
Old May 11, 2011 | 04:10 AM
rh_334's Avatar
rh_334
Maybe on a bad day on Injected's heartbreaker DD
If you wait a couple of weeks i will be finding the limit to modified APS GT28s, on pump gas +meth and race gas.
But there is a car currently at Z1 with a sleeved (3.5L) built block with no heardwork and JWT C2 cams and APS Basic ball bearing kit with Twin GT2871s
This is on 93 pump gas w/o Meth @15psi Tuned with Osiris
Old May 11, 2011 | 06:38 AM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
^^ .64 or .86 a/r ? These are the exact same turbos I bought for the TT build.
Old May 11, 2011 | 06:52 AM
rh_334's Avatar
rh_334
that graph is with stock .64 housings
Old May 11, 2011 | 09:29 AM
Glex25's Avatar
Glex25
I can barely get more than 518whp 550WTQ out of the APS GT28's with 15psi@3k RPM tapering off to 13psi as the RPM go up on a DD
Old May 11, 2011 | 11:16 AM
ace32x's Avatar
ace32x
Hmm. I'm running the pair off the gtm stage 2 kit atm made 530 at 10 psi. Thought these flowed in the upper 7xx's
Old May 11, 2011 | 11:27 AM
rh_334's Avatar
rh_334
Im not sure the exact specs on the GTM GT28s but APS uses a small GT25 compressor housing and relatively undersized .64a/r turbine housing. So you can likely make more. Im not sure why people aren't getting more out of them though, i made 510 on stock block @ 11.5psi with these turbos, and Z1s dynojet consistently makes similar (in some cases lower) numbers that Forged's DD
Old May 11, 2011 | 11:32 AM
ace32x's Avatar
ace32x
Must be a bigger housing then on the gtm ones. They had a lot left in them when we were tuning.
Old May 11, 2011 | 11:40 AM
ace32x's Avatar
ace32x
Debating which direction to go with my build. Limited by the crank and clutch atm I think OS giken twin plate and the stock crank neither of which seem to gulf more than 700 stroker and new clutch are outa the question don't have the $ to fund all that so I was thinking bottom end build with a billet girdle and then springs and retainers in the head and running a twin pump for fuel
Old May 11, 2011 | 12:28 PM
midz350's Avatar
midz350
The stock crank would be fine for your goal. (SP did 1248whp on the stock crank and spin it to 9000RPM )
Per GTM thread :
OS Giken Twin Plate Clutch
-700 ft. lb. capacity (at the wheels)
Also, I don't remember there is a billet girdle for the HR engine since Nissan change the engine design.
Old May 11, 2011 | 12:40 PM
rh_334's Avatar
rh_334
Per GTM thread :
on all of that, stock crank is fine, and no such thing as a billet girdle for an HR since its a one piece main girdle like the GTR, alot stronger than even a billet girdle
OP you need to do some more research
Old May 11, 2011 | 04:43 PM
ace32x's Avatar
ace32x
hmm interesting did not know it was 1 peice, was goign off some information from a friend of mine that i thought was correct! good news tho save me some $ ! ty
Old May 11, 2011 | 05:47 PM
seymore4's Avatar
seymore4
Professional
HR is so much better than DE... SMH
Old May 11, 2011 | 08:40 PM
SH Luciano's Avatar
SH Luciano
with a stock higher comp motor you're already making more power than somebody with ~9:1 built motor...but i do agree i'd be nice to see people making more power with them. i'll let everybody know what my pos makes once it's done, hopefully sometime this month.
Old May 11, 2011 | 09:16 PM
eltness350's Avatar
eltness350
The Untouchable
hey be nice! I like my DE!!
Old May 12, 2011 | 03:20 AM
Xtrix's Avatar
Xtrix
De ftw
