Another GTM Install
Old Nov 1, 2011 | 10:47 AM
  #261
f150intally's Avatar
f150intally
Back on topic...I'm still having some small clicking noises under the car when the chassis is rocking (1st gear accel, decel) but the car is running great. I haven't been able to drive it much because of the rubbing of the rear tires. The fender roller is coming in tomorrow but I'm leaving to take the kiddies to Disney World Wednesday night. I did receive the dyno from Jon at Z1 Motorsports so I'm posting that here. Got some dippity-doos on the top end. Not sure what that is as I haven't been able to ask. Any ideas? The powerband is so broad! I love the way it feels. It comes on really hard at 4k and pulls all the way.
514whp/427tq
Old Nov 6, 2011 | 12:57 PM
  #262
f150intally
anybody experience a metallic ringing noise when the clutch pedal is pressed in? I have the OS GIKEN Twin plate and HD CSC. when at idle and the car is in gear or in neutral, if I press the clutch in I can hear a metallic "ringing" noise like something is loose. Never hear it when the clutch is engaged.
Old Nov 6, 2011 | 12:58 PM
  #263
faiz23's Avatar
faiz23
FEZZZZZZ
Could it be chatter or a throw out bearing????
Old Nov 6, 2011 | 12:59 PM
  #264
dikspiel's Avatar
dikspiel
Chestons Toilet
The flywheel is extremely loud on the os giken twin, perhaps thats what you are talking about? it sounds like there is something wrong even.
Old Nov 6, 2011 | 01:48 PM
  #265
f150intally
I will try to get some audio. It did it from the start.
Old Nov 6, 2011 | 02:57 PM
  #266
binder's Avatar
binder
twin disk clutches are loud. The metal plates between the friction plates will rattle around. It's the same sounds that the dry clutch on ducatis make.
There isn't as much floating around in a single disk clutch to make that kind of noise but when you add 2 or more friction plates with metal plates between then they rattle when pressure is taken off of them.
verdict: normal
Old Nov 6, 2011 | 03:28 PM
  #267
f150intally
Yeah, i'm hoping its not the throw out bearing. I have a feeling to do the throw-out bearing with the GTM kit will require removal of the downpipes.
Old Nov 6, 2011 | 04:46 PM
  #268
f150intally
Here is a good audio clip of the sound I am talking about. It will be a little louder since the phone was under the car recording.
Any ideas on what this sound is? Thanks in advance.
Old Nov 7, 2011 | 10:51 AM
  #269
Rob@Z1's Avatar
Rob@Z1
verdict: normal
The sound clip confirms, sounds like just about any multi-disk clutch.
Old Nov 7, 2011 | 11:19 AM
  #270
dikspiel's Avatar
dikspiel
Chestons Toilet
Mine sounds a lot worse.
Old Nov 7, 2011 | 03:41 PM
  #271
ronn1's Avatar
ronn1
Originally Posted by Resmarted
I'm pretty sure also why we don't get carb approved kits/they all died quick is due to the lack of non illegal tuning systems. No companys wanted to sell their 500hp turbo kits with a godd*mn split second box to blow up a few weeks later. And to be carb approved can't do injector swaps or fuel pump upgrades. So you get very limited to low boost setups. I think if companies came back with Osiris now adays they might actually get a few kits to pass.
Stillen SC is CARB approved and has fuel pump and injector upgrades.
To handle the fuel management for the supercharger system STILLEN has gone directly to the ECU. By changing out to larger injectors and fuel pump (supplied in complete kit) STILLEN is able to take control of the factory ECU and re-map it for the boosted application. This tuning method is handled via reflash using the UPrev software tuned by STILLEN engineers. This supercharger system comes in two options. Either fully tuned (most popular) or Tuner. The tuner kit does not come with any fuel management and comes with no warranty expressed or implied.
Old Nov 7, 2011 | 04:06 PM
  #272
ronn1's Avatar
ronn1
514whp/427tq
That's a TON of HP and torque! Clutch upgrade was a good move...but I gotta tell ya...you're on the ragged edge with the stock internals/tranny/ axles. You have a 600 HP motor now (crank)..double the factory rating.
Old Nov 7, 2011 | 04:29 PM
  #273
f150intally
Thanks. Let's see how it does.
Old Nov 7, 2011 | 04:44 PM
  #274
ronn1's Avatar
ronn1
Keep us posted...have fun with it.
Old Nov 7, 2011 | 05:05 PM
  #275
ace32x's Avatar
ace32x
your enthusiastic with your posts ill give you that... but you need to read a little before making comments like that ^. stock trans driveline and diff on these cars can hold 1200 whp. theres a few shops and private cars that have made that much on them. the only issue with the axles is when running slicks and theres no slip.
Old Nov 7, 2011 | 05:20 PM
  #276
ronn1's Avatar
ronn1
I see you left out the part about other stock internals..namely rods..pistons..bearings.
As to stock driveline (trans/axels) holding 1200whp...please back that statement with specific accounts. I'd love to read about it.
Old Nov 7, 2011 | 07:29 PM
  #277
str8dum1's Avatar
str8dum1
as far as transmissions, every car on the top 25 drag list is on stock pumpkin and drive shaft.
that includes the SP car the injected cars, vinny ten cars, etc.
axles are upgraded based on need, but DS and pumpkins are always stock.
Old Nov 7, 2011 | 08:11 PM
  #278
ace32x's Avatar
ace32x
i made 530 whp on a dynojet on my stock internals and abused the **** out of it until i got contaminated fuel and it owned my valves and piston rings and scarred my cylinder walls. as to how long theyll last it just depends on the tune and how the car is driven. if its a good tune and the cars taken care of it'll last a fair amount of time. but as we all know getting into FI your **** can grenade at any moment. HR has decent rods from the factory and people are just getting to boosting them so we'll see how long the average one lasts. and what str8 said above. look at the top FI numbers all those on there except the auto trans cars are on stock trannys and diffs and majority of them axles aswell.
Old Nov 8, 2011 | 04:09 AM
  #279
f150intally
Just for the record my pumpkin is a Quaife. Still running everything else stock.
Old Nov 9, 2011 | 05:38 PM
  #280
f150intally
Car is running well. Have developed an exhaust leak on the right wastegate recirculation tube. I can here a tat,tat,tat sound under boost. Can only hear it when the windows are up and the radio is turned down. Haven't put it on a rack yet to tighten it up. Hopefully its not an issue. Will keep you posted.
