Vortech rattle help
Old Jul 27, 2011 | 02:00 PM
Tomci08's Avatar
Tomci08
Default Vortech rattle help
I need some input on my vortech rattle and if its something normal or do i need to get it rebuilt. Basically i broke a oil line from my oil cooler last week and the car was leaking oil a little. When i pulled the car into the garage to jack it up i noticed that my vortech sounded a little "off", basically not the same it sounded before. Since this is a v2 blower it is directly tapped into the upper oil pan and shares the oil with the engine. I checked my oil level and it was about halfway between the two markings, would the oil loss make my blower sound different, maybe not get enough oil? I attached a (crappy) video so you can hear the sound. Im not sure if the blower will need a rebuild or if its just starving for oil and making funny noises. Any input is much appreciated. Thanks
Old Jul 27, 2011 | 04:18 PM
str8dum1's Avatar
str8dum1
sounds normal to me. you really didnt lose any oil cuz you never went below the low mark on the stick.
You'll know if you had oil starvation.
Old Jul 27, 2011 | 04:54 PM
rx7/350z's Avatar
rx7/350z
sounds good
Old Aug 1, 2011 | 10:42 PM
ESP350Z's Avatar
ESP350Z
Ive noticed that anytime I get a scare with my car my ears magically hear sounds that were always there, turn ur ac on and the rattle will go away
Old Aug 1, 2011 | 11:41 PM
350z006's Avatar
350z006
^oh...the "classic" vortech idle issue...
Basically, the higher you set your idle, the better the Vortech blower sounds...a lot of people with Vortech adjust their idle higher (~850 to 950 rpm) in order to avoid the Vortech racket at lower idle rpms...when you turn your AC on your idle goes up, which is why the rattle goes away...
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
