350z tn fi questions?
Old Aug 8, 2011 | 09:23 PM
boosted04z's Avatar
boosted04z
Default 350z tn fi questions?
Hello I have an 04 z with turbonetics kit( don't hate) it has low compression pistons and possibly forged rods? Not sure the guy didn't no much about it my question is I have a wideband and it runs great on the tn reflash my question is if I wanted to up the boost from 8-10psi do I need a Retune or would the flash compensate for the extra 2lbs? Please be easy on me im new to zs thanks
Old Aug 9, 2011 | 02:58 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Considering the TN flash wasn't awesome to start with (and some have reported blown motors on the flash), I would recommend getting a different form of EMS and tune for higher boost. If you are willing to find out with the possible consequence of buying a new motor... report back and let us know
Old Aug 9, 2011 | 05:07 AM
tonyzS/C03's Avatar
tonyzS/C03
+1 the reflash may not be bad right now but if you want to up the boost its a must that you get a retune. just for the sake of asking what are your AFR's right now OP?
Old Aug 9, 2011 | 05:17 AM
taywan's Avatar
taywan
hey, same kit, stock internals, was at 6psi, bumped to 9psi, (currently 8psi now)......no retune, a/f couldnt look better, i run 93 or 110
good luck, let us know what she pumps out
Old Aug 9, 2011 | 05:23 AM
binder's Avatar
binder
boo on buying a car from someone that didn't know anything about it. That's just asking for trouble.
"umm ya it has the super rods and the magic pistons. I upgraded the aerodynamics to add another 30 hp in 7th gear. why does it have a 7th gear? oh ya, i opened up the trans and added another gear in there so i can pull harder on top end"
Old Aug 9, 2011 | 08:31 AM
DaveJackson's Avatar
DaveJackson
Master
Whoa! It's like you were right there when they signed the papers!
Good times!
Old Aug 9, 2011 | 03:06 PM
boosted04z's Avatar
boosted04z
II was thinking about getting the utec and my Afrs right now are mid 14s to low 15s at idle same at causing low 11s to 11.7 under boost depending on load
Old Aug 9, 2011 | 03:44 PM
Highway Riding's Avatar
Highway Riding
Spend some time on here and read all the past posts (going back years) in regards to Turbonetics and various EMS/ECU's..... You'll be overwhelmed but eventually you'll lead yourself to a decision!
Old Aug 9, 2011 | 03:59 PM
boosted04z's Avatar
boosted04z
I was thinking. A utec and bigger injectors Idk what size the tn kit comes with
Old Aug 9, 2011 | 04:57 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
forget utec and get an uprev reflash.
Old Aug 9, 2011 | 09:34 PM
boosted04z's Avatar
boosted04z
I don't want to send it to get reflashed Everytime I decide to do something
Old Aug 9, 2011 | 10:13 PM
suprasam's Avatar
suprasam
you should get a retune everytime you change something regarding boost increase, fuel etc. with a uprev reflash you can go to a shop or get the end user version and learn to do it yourself. some of the stand alone have end user versions too.
Old Aug 10, 2011 | 06:01 AM
binder's Avatar
binder
ya, you have to get it dyno tuned. Uprev won't be able to tune it by sending it in without logs and all kinds of things. They actually told me they won't do remote tunes on boosted vehicles since there is too many variables.
Take it to a tuner and have it retuned.
Old Aug 11, 2011 | 06:47 PM
Resmarted's Avatar
Resmarted
Can we just sticky one turbonetics thread and tell people to stop making them?
seriously, there are at least 3 going on all the time....
Old Aug 17, 2011 | 04:51 PM
boosted04z's Avatar
boosted04z
Update recently noticed when in boost it went to 17 on my aem wideband way to lean I stopped , went home did a boost leak test my bov was leaking boost other than that no leaks what could be causing it sometimes it runs good other like today way to leak? Could the reflash be at fault? What's a good engine management system. that isn't a halltec way to expensive please help would a utec or a uprev be good?gotta be better than the tn reflash
Old Aug 17, 2011 | 04:57 PM
bmccann101's Avatar
bmccann101
uprev was already mentioned, buy that.
DONE.
UTEC is a dead art.
Old Aug 17, 2011 | 05:05 PM
Ruthless18x's Avatar
Ruthless18x
The reflash wouldn't cause the boost leak. I'm assuming you just have the raptor valve, It's junk, get a Tial.
How long ago was the reflash? Go with Uprev if available, but a UTEC would fit your goals as well.
Old Aug 17, 2011 | 05:09 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
op does not listen or read. //close thread
_koubie_
Sep 20, 2015 06:34 PM
NYGiants0186
Sep 8, 2015 10:37 AM
