DE build has started, off truck, on stand
Old Aug 25, 2011 | 06:37 AM
binder's Avatar
binder
what are you having trouble with on the cams? cam caps should come off easily and cams should just pull right now.
as for injectors. i used to have a set of DW 800's and they were excellent. I recommend them or DW 600's.
Old Aug 25, 2011 | 07:15 AM
taywan's Avatar
taywan
how many miles on the injects? and the bolt that holds the camshafts on
Old Aug 25, 2011 | 07:16 AM
taywan's Avatar
taywan
Originally Posted by BornSlippyZ
How did I miss this build? Good luck op!
thanks
Old Aug 25, 2011 | 07:18 AM
binder's Avatar
binder
i think you're confused. I'm recommending injectors, not selling injectors.
and cam cap bolts are only torqued to 104 inlbs (7ftlbs). You should be able to unbolt them with a T handle with little effort.
Old Aug 25, 2011 | 07:21 AM
taywan's Avatar
taywan
thanks.
Old Sep 20, 2011 | 04:21 PM
taywan's Avatar
taywan
Attached Thumbnails DE build has started, off truck, on stand-zmtor.jpg   DE build has started, off truck, on stand-zmotor-bottm-end.jpg
Old Sep 20, 2011 | 04:32 PM
CRIDDA's Avatar
CRIDDA
In to check this out
Old Oct 5, 2011 | 02:57 PM
taywan's Avatar
taywan
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
