MissFire, No Codes
Old Aug 24, 2011 | 10:27 AM
OldManZ350's Avatar
OldManZ350
Default MissFire, No Codes
OK, My Car has NEVER missed a Beet before, in till now.
I'm pretty sure it's just Plugs, but I will Explain.......
1. I started remodeling my garage may 1, was finely done Aug 10.....
2. Car sat the whole time with exception of starting car 4-5 times a week, to move in and out of the garage to work.
3. Drove car after sitting 3+ months, got on it easy, ran Fine, then got on it hard 1 time, ran Fine, got on it again 3/4 throttle, had 1 misfire, backed off and when home.
4. Today, put some fresh gas in, so had a 50/50 mix new/old. Drove car seamed fine at first, then got on it 1/2 throttle 4-5k rpm, many misfires. Driving home condition was getting worse, misfiring under less load, so took it very easy. Close to home eased into throttle a bit more, condition seamed to clear up.
I think plugs and/or a dirty MAF. Plugs have about 30,000 miles and MAF is due for a cleaning.
Will change plugs and Clean MAF. I was really just killing some time while car was cooling down, but would still like Experienced Opinions.....
Oh, by the way, this is the reason why my car was sitting so Long, Please see Pic.....
Thanks,
Tim
Attached Thumbnails MissFire, No Codes-p1010007.jpg   MissFire, No Codes-p1010009.jpg   MissFire, No Codes-p1010016.jpg   MissFire, No Codes-p1010017.jpg
Old Aug 24, 2011 | 10:40 AM
str8dum1's Avatar
str8dum1
well until you pull your plugs and check the connections on your coils, we cant help you obviously
its worrisome you didnt get a code. not even a pending misfire code? probably even tell you what cylinder
Old Aug 24, 2011 | 03:52 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Nice fuking garage
Old Aug 24, 2011 | 06:21 PM
Reality350's Avatar
Reality350
Originally Posted by superchargedg
Nice fuking garage
+1 Bada$$
Old Aug 24, 2011 | 07:12 PM
f150intally's Avatar
f150intally
sick garage mang.
Old Aug 25, 2011 | 06:57 AM
binder's Avatar
binder
i doubt this is the problem but a few years ago when i had that misfire problem and was calling you i found the problem to be a loose wire in one of my coil connectors. The pin had wiggled back out of the plug so it wasn't making good connection. Since you haven't touched yours for a while i doubt this would be an issue.
good luck
Old Aug 25, 2011 | 09:19 AM
str8dum1's Avatar
str8dum1
ya mine starting missing the other day out of the blue. same thing, coil not plugged in fully.
but i certainly got a code
Old Aug 25, 2011 | 12:22 PM
OldManZ350's Avatar
OldManZ350
Well, I'm doing Plugs Now and will Look at and check the connections on the Coils.
Thanks Guys......
Old Aug 25, 2011 | 05:59 PM
OldManZ350's Avatar
OldManZ350
All Fixed, New Plugs and Cleaned MAF. Runs Great Again...
Sure is weird that I did not get any codes...
Old Aug 26, 2011 | 07:05 AM
350z006's Avatar
350z006
Awww...darn
I was hoping it was time for you to rebuild your engine and so you could run the YSI setup...
Old Aug 26, 2011 | 01:03 PM
OldManZ350's Avatar
OldManZ350
Ya, part of me was thinking about a Build Also.......
Old Aug 26, 2011 | 02:02 PM
binder's Avatar
binder
mine only threw a random misfire code a few times with all my nonsense. It was doing it for almost a week before that even showed up. Maybe it wasn't a full misfire just a very poor ignition therefore the ecu didn't pick it up as a misfire.
Old Aug 26, 2011 | 06:32 PM
djamps's Avatar
djamps
Yea it probably wasn't a full on misfire, instead it was just bogging down ect. When I lost a coil pack I got random misfire along with the blinking CEL within seconds.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
