FS: PMAS HPX Mass Air Meter MAF Sensor
Old Sep 8, 2011 | 01:41 PM
abarclay's Avatar
abarclay
Default PMAS HPX Mass Air Meter MAF Sensor
SOLD
Condition: Awesome! 9.9/10 (was installed on another car before I got it for maybe a week)
Price: $200 shipped (cost about $250 new)
Reason for Selling: I've decided to go a different route with my Z
Website Description:
As a direct replacement for the original sensor used in all 05 and up Ford products, and many Nissan applications. The Uprev GT sensor has three times more range than the stock sensor, The sensors extended range allows it to be used with engines with as much as 800flywheel horsepower, while still using the stock air cleaner box. This sensor absolutely will not peg, yet still has excellent resolution. Tuning is required.
As an addition to fabricated ducting. Due to its design, this sensor can easily be added to any piece of existing ducting. It can be used in both blow through and draw through applications, The sensor is calibrated so that its range just slightly exceeds that of the ducting in which it is installed. This means that the sensor cannot peg, yet still has excellent resolution. Tuning is required, It will support up to 800hp in a 3" diameter tube, up to 1100hp in a 3.5" diameter tube, and up to 1500hp in a 4" diameter tube.
UpRev MAF GT sensor will read almost 180% the air flow range of the factory sensor while allowing stable idle air flow measurements. If you have a Nissan or Infiniti vehicle that you're adding Forced Induction to, you will need this upgraded MAF Sensor. We've worked for many years to offer a MAF sensor that we can put our name on. Finally we have the right sensor. Years of being the only manufacturer to support Forced Induction properly on the Nissan vehicles using the factory ECU has allowed us to understand what our customers need and this is the product we've brought to market.
Old Sep 10, 2011 | 05:32 PM
r1forever's Avatar
r1forever
pm sent
Old Sep 12, 2011 | 01:05 PM
abarclay's Avatar
abarclay
SOLD
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
