Exhaust: Dual 60mm to Single 76.3mm
Old Sep 12, 2011 | 06:53 PM
Resmarted's Avatar
Resmarted
well a good quickhand way of comparing exhaust flows is just looking at the pipe (diameter) volume.
piR^2
That tells us that the dual 2.25 has more area, BUT again this isn't the correct way to do things. The correct way involves some more serious mathematical calculations, and I'm pretty sure nobody here wants to do a triple integral or has the software to do it for them.
I'd say go bigger diameter downpipes and single exhaust, because that will be a great improvement. 2.5" downpipes to 3" should in total out flow your current system. But a full 3" (3" downpipes to 3" single) would be even better. That should actually net you some power and response, while the 3" muffler section will keep your car on the quieter side. 4" pipes are always loud regardless of what mufflers you put on there, they have just a very big deep tone. If you are too loud, just buy a cheap silencer for your tip.
Old Sep 12, 2011 | 06:55 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
i would def say go 4". I think PF supercars sells a single 4". I was gonna try NA but would have been a waste. But i knew it would have sounded good
Old Sep 13, 2011 | 06:40 AM
RandomHer0's Avatar
RandomHer0
All good I could talk all day about it.
Last year was the year of cooling for me and I've never had a single issue, including some hour long enduro races I ran last year and this year.
Big Koyo Rad 53mm running only water and water wetter.
Big Opening Kuruma Z Bumper (I have a G)
Big (19 Row) GTM oil cooler mounted passenger side bumper opening.
This winter I want to get some ducts to the brakes, I currently use Ti Shims to help with fade
Word, me too. A little off topic but do you run into any temperature issues? I've done almost every cooling mod, and taken every precaution possible to avoid problems.
Are you running an oil cooler? Where did you mount so that the intercooler isn't in the way?
Old Sep 13, 2011 | 06:44 AM
RandomHer0's Avatar
RandomHer0
See I spoke with Tony from Motordyne and he suggest I don't do 3" turbo back, apparently even turbos need some back-pressure.
So the setup would be from downpipes, to 2.5" Fast Intention Test pipes, to 2.5" y-pipe, to 3" single y-back.
piR^2
Old Sep 13, 2011 | 06:50 AM
Ruthless18x's Avatar
Ruthless18x
Awesome. Thanks for the pics man.
Old Sep 13, 2011 | 06:59 AM
k6750gsxr's Avatar
k6750gsxr
Here is a good read for what its worth to the cnvo.
http://www.tercelreference.com/terce...st_theory.html
Old Sep 13, 2011 | 07:32 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Hey OP,
My buddy Brian was making 550whp with a JIC Y-pipe to a 3" JIC single exhaust. He had Greddy TT kit as well. Hope that info helps.
https://my350z.com/forum/3855413-post37.html
Old Sep 13, 2011 | 08:17 AM
RandomHer0's Avatar
RandomHer0
Thats what Im talkin about, thank you, much appreciated.
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
