My long awaited Greddy TT Build list!!!!!!!!
Old Sep 14, 2011 | 08:57 PM
Ztouring04's Avatar
Ztouring04
Default My long awaited Greddy TT Build list!!!!!!!! Updated 12/9/12
12/9/12 UPDATE... Almost a year later!!!(Non-readers Beware)
Ok. So after the car was tuned with the Uprev Osiris I started having some problems. Hot/cold starts were bad, idle was awful, car felt sluggish. I would slow down, put the car in neutral and it was shut off!! I put up with it for awhile until one day the car wouldn't run longer then 2 minutes.. It would smoke like crazy when I gave it gas to keep it idle, then off!! It almost felt as if something was choking it... I let it sit for a week until I could get it to the shop. In the mean-time I ordered some K&N air filters to replace the shitty Greddy cones. I don't know if its a coincidence or not but the car started right up after the install. So I had the car put on a trailer and sent to HP LOGIC for re-tune and install or CJM stage 0 fuel return and a turbo timer.
Fast forward I just got the car back yesterday, after the shop spending some needed time, the car feels amazing. The fuel system and turbo timer were installed. The car was re-tuned on 9 psi and made 405rwhp/345tq on HP Logic's low-reading mustang dyno!! (est. 445rwhp/385tq dynojet). Feels great! Boost kicks in at low rpms and holds strong! Idle is 100 times better, no more shutting off and starts seems to be perfect. I am very happy with the new results...
So here is the updated build list now:
Greddy 18g TWIN TURBO kit
Greddy intercooler kit
AAM Dual 3” Exhaust
AAM 3" open dump pipes
Tial “Q” 50mm BOV
Walbro 255LPH fuel pump
DW 600cc injectors
CJM Stage-0 fuel return
K&N intake air filters
NGK 1-stage cooler spark plugs
AAM competition oil pan spacer with SS lines
GReddy Oil Catch Tank
Stillen Ground wire Kit
Powerlab 3/8 Plenum Spacer
Osiris Tune
Uprev MAF GT
JWT clutch/flywheel
Concept Z Performance stainless clutch line
CZP Upgrade clutch pivot ball
DEFI BF 60mm gauges (Boost, fuel pressure, exhaust temp)
DEFI link advance control unit
Blitz SBC i-D boost controller
HKS turbo timer
Heres some new pictures:
Some crappy cell phone pics:
OLD PICTURES
Take a look let me know what you think! thanks!!
Old Sep 14, 2011 | 09:14 PM
herrschaft's Avatar
herrschaft
18G or 20G turbos?
Interested to see how quickly they spool with the 3" exhaust.
Old Sep 14, 2011 | 09:24 PM
Ztouring04's Avatar
Ztouring04
Sorry...18g
Old Sep 14, 2011 | 10:09 PM
ImWeeZzel's Avatar
ImWeeZzel
gl with your build, im curious as to why you are running w/ an oil pan spacer + stainless steel lines
Old Sep 14, 2011 | 10:54 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Sweeet dude! Congrats
Old Sep 14, 2011 | 11:08 PM
ITOzann's Avatar
ITOzann
NICE!
Old Sep 14, 2011 | 11:14 PM
Czarrr's Avatar
Czarrr
My long future dream from now. To be boosted.
Congradulations on the set up.
Knock on wood.
I hope your motor doesn't go boom!
Old Sep 15, 2011 | 03:58 AM
Resmarted's Avatar
Resmarted
Car is dope blacked out, except not really a fan of the tail-lights.
Build sounds equally good, but (mainly out of curiosity) why not have the car originally tuned with meth+water?
Old Sep 15, 2011 | 05:18 AM
Alberto's Avatar
Alberto
Cranky FI Owner
The AAM oil pan spacer doesnt get along with the Greddy pan-using the supplied bolts, as I believe they are a c*nt hair too short? Its been years ....
I had some bolts strip out of the threads, and years ago Sharif told me he just runs the Greddy pan or the stock pan and AAM spacer as he had seen it on numerous vehicles. Just be careful as you wont notice till you pull it apart maybe for a build, the gasket sealer kept everything in check with mine even though 4 holes needed to be helicoiled.
Good mods list, good luck with the build!
Old Sep 15, 2011 | 06:20 AM
Ruthless18x's Avatar
Ruthless18x
I think by the ss lines he means replacement lines for oil return, rather than the DIY rubber ones the Greddy comes with. I swapped to AAM's.
I found this out last weekend. I'm ordering new bolts because I want to run both for the extra quart and AN return lines.
Old Sep 15, 2011 | 08:44 AM
ImWeeZzel's Avatar
ImWeeZzel
Makes sense to have stainless steel lines for strength and durability. What I was referring to was that some kits a tap or spacer has to be added to the oil pan for the oil lines, which its not necessary for the greddy kit.
I would save some money and just get an oil cooler kit instead. Ruthizzle, I've been waiting on your build bruh.
Old Sep 15, 2011 | 01:57 PM
Ztouring04's Avatar
Ztouring04
thanks guys..i am going to run the AAM oil pan spacer with the stock oil pan i do not have the greddy one.
Old Sep 15, 2011 | 02:26 PM
gang unit's Avatar
gang unit
What's your HP goal? Under 500 or 600? Reason I ask since I don't see any fuel return system/kit on your shopping list :-). Contact CJM (Phunk) if you're looking to get it. Good luck with your build!!! Keep us informed Ned
Old Sep 15, 2011 | 02:31 PM
Ztouring04's Avatar
Ztouring04
Right now the goal is 400rwhp stock block. When build the block I'll will do fuel system and meth kit
Old Sep 15, 2011 | 02:34 PM
Ruthless18x
You should run E85 and sell me your AAM dps and dump tubes.
Old Sep 15, 2011 | 04:54 PM
Ztouring04's Avatar
Ztouring04
^ haha any updates on your car your build list looks insane!!
Old Sep 16, 2011 | 07:23 AM
CTZ860's Avatar
CTZ860
Sounds pretty modest....doubt ull have any trouble at all hittin that.
Old Sep 16, 2011 | 07:54 AM
Total D's Avatar
Total D
Looks like something fun in the making...Look forward to final product
Old Sep 16, 2011 | 02:21 PM
Ztouring04's Avatar
Ztouring04
Thanks man me too
Old Sep 16, 2011 | 10:19 PM
Ztouring04's Avatar
Ztouring04
I will post install pics as the build progresses
