650 idle ok for FI?
Old Sep 20, 2011 | 06:31 PM
jvelos3's Avatar
jvelos3
Default 650 idle ok for FI?
I got a stock motor with Turbonetics ST kit.
When I was running the reflash I was at ~850-900rpm idle and sometimes it would stumble. Apparently this was a common problem with the reflash on the TN kits. I just got tuned with uprev and my tuner dropped the idle to stock...650rpm idle. It idles fine. Throwout bearing noise is a lot more apparent but it seems to run very smooth. I asked him about the idle but he said there's no reason for me to have been idling at 850-900rpm.
Was there a particular reason the TN reflash was running at 850-900rpm idle?
Old Sep 20, 2011 | 06:36 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
On stock motor... stock idle rpm is ok assuming the other components are able to idle there (cams, injectors etc). Some built engines will require an idle bump to increase oil pressure at idle depending how it was built / intended for.
Old Sep 20, 2011 | 07:26 PM
Boosted Performance's Avatar
Boosted Performance
My stock block turbo car (with Haltech) is very happy idline at 650rpm. It has been like that for a couple of years now.
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
