350z single turbo tuning problems
Old Oct 27, 2011 | 02:21 PM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
Funny I said the same thing about the 550 map and not washing out the cylinders via pm to him. Sounds like we're all on the same page here... holy sh*t that's scary.
Old Oct 27, 2011 | 04:35 PM
hellaz33's Avatar
hellaz33
Originally Posted by str8dum1
sounds liek your tuner is already creating himself a way out if something goes wrong. That would make me very nervous. There's no saying that he wont cause damage but is already pointing fingers at you if something does happen.
that 550cc map would put you pretty close under vacuum and in no way rich enough to wash the cylinders.
Did you notice the symptoms driving over to the shop that the tuner is talking about?
The VTC can make a racket for a few seconds after startup. Who knows if that's what he heard.
Go back to stock ECU would be 1st step. Car should fire right up and idle nice and smooth. If it doesnt, you need to check fuel pressure.
Do you have the UTEC properly grounded?
I believe i have it grounded correctly i have the black wire coming from the small white pin connector going to a mount that previously held my stock ecu i have it connected with an eylet around a bolt. The red wire (the only other wire in this connector) i do not have connected to anything as i think this is not needed. is this correct???
Old Oct 28, 2011 | 07:36 AM
tylerxfire's Avatar
tylerxfire
are the plugs installed correctly..maybe its missing?
Old Oct 28, 2011 | 11:20 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
check coils 4 and 6(driverside back two coils) the leads are long enough to switch them and i have seen it happen a few times. 4 plugs will look good and those 2 will be drenched in fuel.
As far as the utec im sure you can get it to run pretty good but will 600cc injectors at idle and cruising it will be tough to get perfect..
Old Oct 28, 2011 | 07:52 PM
UMW350Z's Avatar
UMW350Z
my powerlab kit ran like **** with the UTEC, even after a retune, although the UTEC it self probably is not your problem you are describing.
bcoffee20
Nov 19, 2015 06:39 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
fst100
North East
Sep 8, 2015 11:37 AM
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
