necessary to thermal coat the manifolds?
Old Nov 12, 2011 | 03:30 AM
ccchaorule's Avatar
ccchaorule
Default necessary to thermal coat the manifolds?
all my parts are here and everything is about to go in.. but right before i have my turbo manifolds in should i thermal coat them?? it costs around 200 bux for the pair.. but would it make a bigg difference?? i got my greddy twin turbo kit used and it already came wrapped in some sort of heat wrap.. i just had my turbos rebuilt so they should be like new, but would you guys recommend thermal coating them?? thankss.
Old Nov 12, 2011 | 03:37 AM
ccchaorule's Avatar
ccchaorule
reliability is my main concern, would this make this it more reliable or would it increase its perfornance?? my shop told me it would do a lil bit of both.. but not it doesnt seem like that many people thermal coated there manifolds on here..
Old Nov 12, 2011 | 04:54 AM
Cass007's Avatar
Cass007
It can reduce heat a bit and trap more heat inside which may make them minimally more efficient. I had mine done, outisides only so if it flakes it wouldn't end up in the turbo.
I believe the general concensus is to coat or wrap, but not both.
Old Nov 12, 2011 | 06:36 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Necessary? No. Recommended, advantageous, and relatively cheap to do? Yes.
Old Nov 12, 2011 | 07:01 AM
binder's Avatar
binder
+1
after watching vids from under my car this last dyno tune i won't do anything without heat wrap or coating. My turbo was GLOWING as well my wastegate. Anything to keep heat from melting down my engine is nice
Old Nov 12, 2011 | 07:32 AM
GreenGoblin's Avatar
GreenGoblin
Well said Rude
Old Nov 12, 2011 | 11:22 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I also did the hot side of the turbos, down pipes and most pipes that are close to the turbos/manifolds. Now is the time to do it before you get it all in, I regretted not doing it the first time, my turbos and down pipes also were a cherry red on the dyno.
Not required but recommended.
Old Nov 12, 2011 | 11:59 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
+1
I also chose to get the entire hot side of the kit coated, including the turbine housing and the down pipe.
Old Nov 13, 2011 | 01:59 AM
ccchaorule's Avatar
ccchaorule
also i see alot of people with the greddy kit but instead of the cheap intake pipe that comes with the kit they have one that is chromed out and nice looking?? is there a company that makes intake piping that comes off the upper plenum??
Old Nov 13, 2011 | 02:50 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
They're likely just getting those cold side pipes polished; not chromed.
