overheating under boost, but not load
Old Nov 24, 2011 | 09:21 AM
str8dum1's Avatar
str8dum1
well they are the only option so by default...
Originally Posted by binder
yes, before they switched their design a few years ago. They have always been the "go to" for the large bore cars.
Old Nov 28, 2011 | 12:37 PM
ace32x's Avatar
ace32x
started taking the front apart a little today to get the motor out. Need to pick up the tool to disconnect the ac lines and the whole front should pull off fans radiator intercooler all in one peice
Old Nov 28, 2011 | 01:11 PM
VQ35deMax's Avatar
VQ35deMax
In for results.
Old Nov 28, 2011 | 01:52 PM
Cass007's Avatar
Cass007
Ace, good luck with the tool. I've done it a few times and the best success I've had is with the plastic ones from Harbor Freight. I use the size that is too small and cut another one up to fit the piece that it needs to be the right size. I've tried two or three different sets and never got them to work correctly.
Old Nov 28, 2011 | 02:29 PM
ace32x's Avatar
ace32x
hmmm... sob lol. maybe ill just disconnect it at the flange on the ac pump and take the whole unit out and not even bother with it XD
Old Nov 28, 2011 | 05:29 PM
ace32x's Avatar
ace32x
disconnected everything i could get to and plenum and fuel rails came out. injector clips need to be replaced they were rotted pretty good it seems.
Old Nov 28, 2011 | 06:01 PM
binder's Avatar
binder
details details....
but they do hold their power so they should be ok for other builds.
Old Nov 28, 2011 | 06:03 PM
binder's Avatar
binder
those are the ones i used!!! love harbor freight.
on a side note, i took my engine out twice with just swinging my a/c condenser out to the side. The last time i just took them apart. The harbor freight clips worked good but actually getting the lines apart was a bioch. They were stuck together pretty hard.
Old Nov 28, 2011 | 06:07 PM
Cass007's Avatar
Cass007
Looking at your car is giving me flashbacks ace it reminds me of how its looked too many times in the past 3 years.
Old Nov 28, 2011 | 06:13 PM
ace32x's Avatar
ace32x
lmao XD, this is new to me. my HR in my other Z is actually fairly different then this everything got moved around a bit
Old Nov 28, 2011 | 06:21 PM
binder's Avatar
binder
DE>everything
Old Nov 30, 2011 | 11:53 AM
Rob@Z1's Avatar
Rob@Z1
DE>everything
THIS!
Goodluck OP
Old Feb 7, 2012 | 07:57 AM
ace32x's Avatar
ace32x
late update, got it all torn down finally. headgasket failed on cylinder 1 and 3
Old Feb 7, 2012 | 09:36 AM
bigcloud's Avatar
bigcloud
That's good you found the failure. What are you going to do now? Just replace the head gasket? Or is there more wrong with the motor?
Old Feb 7, 2012 | 10:11 AM
ace32x's Avatar
ace32x
that was all that was wrong, it did have standard arp studs though so im switching those out. While im in there its getting Arp L19's, cosworth or dynasty headgaskets, rev up oil pump, pathfinder cooling mod, whole engine gasket rebuild kit, and new spark plugs
Old Feb 7, 2012 | 01:19 PM
bigcloud's Avatar
bigcloud
Nice! So you will be back on the road in no time!
Old Feb 7, 2012 | 03:23 PM
jtroger2212's Avatar
jtroger2212
[QUOTE=binder;9483930]if a dumbass assembled it then it could have a bad headgasket from mile 1.
+1 for Jeff's comment. Going through this on my car now.
Old Feb 7, 2012 | 05:06 PM
  #38
ace32x's Avatar
ace32x
up for sale in no time !
Old Feb 14, 2012 | 03:03 PM
  #39
athens2jz's Avatar
athens2jz
i had this problem also, i added a high pressure rad cap, and replaced the thermostat. the overflow tank never fills to max anymore but the coolant is still dirty( don't have a catch can). also the overheating problems disappeared. prob not a solution to the problem but it did treat the symptoms. I plan on building this block down the road so this solution helped me be able to drive the car and still race it till it get built.
Old Feb 23, 2012 | 03:04 PM
  #40
ace32x's Avatar
ace32x
rebuild kit arrived finally with a pathfinder and some l19s and cosworth HGs ;D
