Veyron Fuel Pump
Old Dec 12, 2011 | 05:12 AM
Resmarted's Avatar
Resmarted
Default Veyron Fuel Pump
There really isn't that much data on the veyron pump, so I was herpaderpin looking up sh*t about it and stumbled upon this...
I think this should be the new go to pump... I was bummed to see it was actually rated at 330lph, but when you take into consideration what it flows at higher voltages it's pretty damn boss. I could be wrong but I'm willing to bet the size of this pump lets it take those higher voltages like a boss. Glad I chose it over an a1000, or twin 255's now.
What do you guys have to say?
(not sure what to expect now, I'm used to trolling not really contributing )
EDIT:
Holy jeesus. That pic is huge. Idk how to make it smaller....
Old Dec 12, 2011 | 06:35 AM
str8dum1's Avatar
str8dum1
ya not much different than a drop in/no modification Aeromotive 340L. An aeromotive on a BAP would produce similar numbers.
My dual pump on my BAP flow ~550LPH at 16.5V at 60psi. Veyron pump flows 25% less.
At only 13.5V dual pump flows 480LPH (at worse 440LPH) at 60psi. 30%(25%) more than the veyron pump.
Sounds like you made a good choice, if you want less fuel, a non-standard install, or no manufacturer support if the pump has issues (although I'm sure IP would easily handle any issues). Veyron has even gone to a newer revision of that pump and no longer uses that model that IP sells.
255LPH testing
Old Dec 12, 2011 | 07:50 AM
bmccann101's Avatar
bmccann101
werd.
these threads make me feel better about my choice. and thats all i really care about> haha
Old Dec 12, 2011 | 08:14 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
How do you plan on pushing more than ~14.5V to the pump?
Old Dec 12, 2011 | 08:20 AM
konrad's Avatar
konrad
Boost a pump
Old Dec 12, 2011 | 11:35 AM
Alberto's Avatar
Alberto
Cranky FI Owner
This is gonna be the coolest mod that people mention with slow cars.
"my car has Veryron fuel pump brah"
<------walks away
Old Dec 12, 2011 | 11:51 AM
ace32x's Avatar
ace32x
<------walks away
check out my pump breh
Old Dec 12, 2011 | 11:57 AM
graffkid732's Avatar
graffkid732
<------walks away
Haha
Old Dec 12, 2011 | 12:00 PM
Alberto's Avatar
Alberto
Cranky FI Owner
"You hear that? You hear that whining?.....Veyron pump son"
Old Dec 12, 2011 | 12:07 PM
ace32x's Avatar
ace32x
Old Dec 12, 2011 | 12:09 PM
konrad's Avatar
konrad
In the January Dsport magazine they flow tested the A340 pump at RC. @14v 60psi fuel pressure 480lph, 75psi fuel pressure 430lph that's 30psi of boost and they rate that at 1000whp
F*** varon pump
Old Dec 12, 2011 | 02:18 PM
Resmarted's Avatar
Resmarted
<------walks away
LOL
maybe if it wasn't such a ***** to install. It's about as big as you could fit in-tank i'd say and it's far from a straight swap. Plus you need to make a relay. And I know my car will be far from slow
@Str8, if you search wsp330 in google you should find the ad where I found this data. It's definitely not from IP/Dynosty, so maybe it's the newer version (hopefully not for my sake lol)?
Old Dec 12, 2011 | 02:22 PM
Resmarted's Avatar
Resmarted
F*** varon pump
Damn, that's a quite a bit.
Not saying the veyron pump is still better, but I'd like to see independent testing of they wsp330. Maybe this data's off? Again the size of this thing would make me think it can out flow a standard 255 sized drop in pump.
Either way potential for 460lph at 60 psi with a boost a pump is just fine for me!
Old Dec 12, 2011 | 04:49 PM
konrad's Avatar
konrad
yeah not sure how accurate that is, coz str8 said twin pump flows 480, not so sure that a single a340 would flow almost as much.
Didnt we have someone from Dsport magazine on this site? maybe they can confirm this
Old Dec 12, 2011 | 05:35 PM
str8dum1's Avatar
str8dum1
AFAIK only version 1 of teh veyron pump was ever available to the grey market. Apparently veyron dealers are not supposed to sell the pumps at all, but a batch of the version 1 pumps made its way onto the market to places like IP.
With drop in so close to the same flow and the veyron pump so $$$, i never really investigated it anymore.
Old Dec 12, 2011 | 05:41 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
FWIW, I use 1 Veyron pump in my black 350Z. It is not a dropin solution at all, but is extremely quiet (quieter than a twin pump) and flows for days.
That being said, the new Walbro 400 http://www.dynosty.com/2011/08/walbro-400-fuel-pump/ is possible to fit in the stock pump hanger with modification and boasts big performance.
Old Dec 12, 2011 | 06:44 PM
Vas_Z33's Avatar
Vas_Z33
Hal^ how much modification does that require? I want it
Old Dec 12, 2011 | 07:06 PM
Dynosty's Avatar
Dynosty
Which one? The Walbro 400 is not too bad at all. The Veyron pump... is a serious chore. I had a day's work and testing to get it all right in my car.
Old Dec 12, 2011 | 09:26 PM
Resmarted's Avatar
Resmarted
Hal you think you could pm me about the gauge wiring you used? I know we established it needed a relay, but I'd be open to recommendations
and I'll be sending you guys my oem ecu for a reflash/ordering another batch of parts right around the bend.
Old Dec 13, 2011 | 06:37 AM
str8dum1's Avatar
str8dum1
depends on where you are pulling your power from. I have a 0ga running to the trunk, so I run a 10Ga to my fuel pumps. 10ga from the front of the car would also be sufficient based upon the amperage vs wire length charts available online.
