HKS SC Setup, Engine bogs after some events
Old Jan 18, 2012 | 01:01 PM
djamps's Avatar
djamps
Originally Posted by lanceccs
Back to looking at the MAF. Ordered upRev GT MAF, pending arrival.
FYI the car is going to run like total shyt, if at all, until you completely retune it after swapping MAF.
Old Jan 20, 2012 | 05:28 PM
lanceccs's Avatar
lanceccs
Yes, I am planning to retune after putting it on.
If replacing MAF doesnt fix the problem then I am totally lost!
Old Jan 20, 2012 | 05:41 PM
lanceccs's Avatar
lanceccs
Will check for intake and exhaust leaks.
Btw, I've concluded that It has nothing to do with the rear sensors because there is absolutely no change in behavior with and without both of them.
Good thing is I can simulate the engine cut 100% of the time thus troubleshooting is easier.
It cuts at 4000+ RPM boost around 0.5 bar.
After cut, the engine doesn't stall but doesn't respond to throttle for 3 to 5 seconds. When it starts to respond after that, the rpm doesnt go above 2.5k.
I suppose that is the limp mode.
Off the engine for a good few seconds and restart to restore. If you off and turn it on immediately, the problem wouldntt go away.
Originally Posted by pez1111
Check your entire exhaust system for any cracks and leaks . They may not be visible but you need to eliminate any leaks because the rear sensors may be seeing too much oxygen and dumping fuel.
Old Jan 27, 2012 | 09:12 AM
dorkstar's Avatar
dorkstar
I'm having similar prob on my Vortech Z, The street My car was parked on flooded. I moved my car didnt drive it for a few days. Today drove it to work and it chokes at 3000rpm. Besides that it drives fine in the lower RPM I think I have water somewhere also.
Old Jan 30, 2012 | 07:17 AM
lanceccs's Avatar
lanceccs
problem resolved after putting in GT uprev maf.
So conclusion is, my stock maf was dying.
Thanks all!
Old Jan 30, 2012 | 12:22 PM
pez1111's Avatar
pez1111
Well done . Thanks for the follow up , good info.
_bit
Oct 2, 2015 07:49 AM
