Opinions need on this build
Old Jan 8, 2012 | 07:00 PM
mexicutioner350's Avatar
mexicutioner350
Default Opinions need on this build
Hello guys name is jose I'm kinda new to this form but usually I'm selling parts. I kinda know some things about engine building and want to get an over all opnion on my build. Im looking for around maybe 7k build but it will take me time. Money is not really an issue not saying I'm rich but I'm a waiting type of person. I'm looking for 500-550hp not big just enjoy to get going. Im also looking for parts too so if you have any that I'm looking for I'm interested.
Well enough is said this is my build...
Cp forged pistons and manley turbo tuff rods
arp head studs and main studs
arp l19 head bolt kit
head gasket
brian crower cams or cosworth or any cams of that high caliber
was wondering do i need the ferrea 350z full valve/dual spring kit?? i saw that i can get the brain crower values and springs cheaper than the ferrea whole kit idk not trying to go cheap but would love to save money too.
please comment and let me know if I'm missing anything else thank you for all your help
Old Jan 8, 2012 | 07:09 PM
konrad's Avatar
konrad
I have a set of ARP main studs that were torqued once, on my previous build. I'm willing to let them go cheap. let me know if you interested
Old Jan 9, 2012 | 04:15 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We have experience with both, and Ferrea is a higher quality product but BC gets it done for 9 out of 10 builds. What will you be doing with your built motor? Intended use? Don't forget supporting mods such as fuel system and engine management.
If you have not already purchased your parts, please give us a call! We stock most of the parts you need and have great deals!
Old Jan 9, 2012 | 05:34 AM
psychoballistic's Avatar
psychoballistic
I run the BC 3 cams with their spring and retainer setup. If I were to do it again, I would go Ferrea valves with their spring setup. I think with the higher revving setups and massive stress being put on the springs, they have better quality to offer. But again, for 500-550 you will be fine with a BC 2 set or JWT set of cams, and the issue is not nearly as pertinent as if you were running 700+whp and revving out to 8k.
Old Jan 9, 2012 | 06:47 AM
djamps's Avatar
djamps
Stock heads and cams will get you 5xx whp without any trouble.
Old Jan 9, 2012 | 07:08 AM
Ryan@Forged's Avatar
Ryan@Forged
For those numbers you would be fine with a set of JWT cams and spring kit paired with a built shortblock. We sell our shortblocks for $3490 + core exchange http://www.forgedperformance.com/sto...at=1837&page=1
The other items can be added for well below your budget. Let us know if we can help in any way.
Old Jan 9, 2012 | 12:11 PM
seymore4's Avatar
seymore4
Professional
I've got a set of 8:1 cosworth pistons for sale, brand new with rings. PM me if you're interested
Old Jan 15, 2012 | 04:26 PM
mexicutioner350
how much for the pistons and sorry about the wait been busy with work
Old Jan 15, 2012 | 04:52 PM
binder's Avatar
binder
either of those valve springs and retains will work great. I have ferrea but a lot of members use BC.
If you plan on reving past 7500rpms i would recommend them. Since the engine has miles on it it would be smart to freshen up the heads while doing cams anyway.
Old Jan 15, 2012 | 04:59 PM
Ruthless18x's Avatar
Ruthless18x
What turbo kit are you looking at?
Old Jan 15, 2012 | 07:46 PM
STL 350Z's Avatar
STL 350Z
Good luck OP... I am putting together my list of things too. Lots of good info here!
Old Jan 16, 2012 | 10:13 AM
mexicutioner350
either a single turbo or a remount but i just need the turbo piping i bought a precision turbo have a intercooler need the ecu injectors fuel pump
Old Jan 16, 2012 | 10:14 AM
mexicutioner350
should i still freshen up the heads with only 38,000 miles on it and how much you think it would cost thanks i appreciate all of these comments
Old Jan 16, 2012 | 10:24 AM
seymore4's Avatar
seymore4
Professional
+1,000,000
You're on a budget leave the heads alone. You will have no problem making 500 ish whp with stock heads and cams, this stuff gets really expensive really fast. Unless you have a specific reason for doing cams/valvesprings/retainers like you want to rev to 8000 or make a million HP I'd say leave them alone and save your money
Old Jan 16, 2012 | 10:29 AM
mexicutioner350
Originally Posted by seymore4
+1,000,000
true i already looked at everything and it turned out to like 6k and thats without mechanic work but I'm hoping i can work on it with my grandpa but i may do cams maybe
Old Jan 16, 2012 | 10:34 AM
seymore4's Avatar
seymore4
Professional
If you do cams you will need valvesprings and retainers as well.
Keep in mind you're going to need other supporting mods such as a return fuel system, upgraded clutch, possibly gauges/ boost controller, tuning etc. For the ECU look into Osiris, a lot of guys will recommend a haltech but for your goals Osiris is more than sufficient and also the most cost effective solution.
You can save a lot of money if you have time and the ability to do the work yourself tho.
Old Jan 16, 2012 | 12:17 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
You are giving bad advice if you think its fine to run just Osiris on a built motor.
Old Jan 16, 2012 | 12:28 PM
seymore4's Avatar
seymore4
Professional
Didn't you have a multi-page discussion with my friend ace32x about this? Neither of us are having any issues with it, I'm going on 20K miles at 570whp and he put down something like 680 with his Brian Crower stroker... runs like a champ. Per Rich and Jared at uprev they've tuned up to 800whp with just Osiris, not really seeing a need to throw extra cash at something that works just fine
Old Jan 16, 2012 | 12:33 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
I'm not saying it won't work but I wouldn't recommend it. If you want to cut corners on your own build that's fine but just because something works doesn't mean it is the best way to go about it.
Old Jan 16, 2012 | 01:31 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I have Ferrea Titanium valve springs with under 5,000miles on them I would sell for $100 shipped to you.
