DE headgasgets, deciding on which.
Old Jan 13, 2012 | 07:22 AM
psychoballistic's Avatar
psychoballistic
I have HKS and ZERO issues with them... Very pleased overall. Go ARP for all your hardware. Why run the risk of possibly pushing the limits of HR hardware when you can get a good deal with a little bit of searching? I run ARP everything and am very pleased.
Old Jan 13, 2012 | 07:26 AM
ace32x's Avatar
ace32x
ya i planned on running all ARP hardware, worken great so far on my other build aswell
Old Jan 13, 2012 | 07:27 AM
ace32x's Avatar
ace32x
Originally Posted by jerryd87
thats actually the first place i have seen at that price, actually the first place ive seen sell the cosworths as a pair period. most places are selling them for 240-260 per side.
same best ive seen was 260 per side until this
Old Jan 13, 2012 | 09:53 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
that might be a mistake in the description dont think they sell them individually.
Old Jan 13, 2012 | 10:16 AM
streetzlegend's Avatar
streetzlegend
HR Head gasket and L19s. Isnt there someone running 9's with this setup. With L19s I really doubt there would be any issues below 1000hp, plus it has better coolant passages than DE gasket
EDIT:
https://my350z.com/forum/forced-indu...ace-motor.html
L19 and HR OEM Head Gaskets
Old Jan 13, 2012 | 10:34 AM
ace32x's Avatar
ace32x
EDIT:
trying to avoid machining time on the block to get the hr gasket to work
Old Jan 13, 2012 | 10:52 AM
streetzlegend
It is extremely simple to do, do it yourself with a dremel, I and others I know have done it. I have 30k miles on mine, no issues.
Go to the JWT site and look for a PDF with details on how much to shave off.
Old Jan 13, 2012 | 11:29 AM
ace32x's Avatar
ace32x
i confirmed with them when i called that the price was per side and was a total of $560 for a pair after shipping
Old Jan 13, 2012 | 11:40 AM
streetzlegend
yikes, thats more expensive than Eagle Rods
Old Jan 13, 2012 | 11:48 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
hmm im worried i only ordered one side now...
does this look like oem or cosworth headgaskets? or is it pretty difficult to tell
Old Jan 13, 2012 | 12:10 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Kyle @ IPP says they don't look stock, phew.
Old Jan 13, 2012 | 01:24 PM
ace32x's Avatar
ace32x
did you order them from thm? I'm ordering those if thats the case for $260!!
Old Jan 13, 2012 | 01:36 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
I ordered them from Fontana Nissan because I had to get a revup oil pump.
Old Jan 13, 2012 | 01:38 PM
ace32x's Avatar
ace32x
same price? im picking up a rev up oil pump aswell for it so i need that too :P
Old Jan 13, 2012 | 02:03 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
http://www.nissanraceshop.com/produc...q35de-2000090x
Old Jan 13, 2012 | 03:07 PM
konrad's Avatar
konrad
That's not oem, oem is ss with just the area around the sleeve black
Old Jan 14, 2012 | 10:21 AM
binder's Avatar
binder
I know this has been said by others but those don't look like the oem gaskets that came out of my engine. Oem aren't coated on the entire gasket.
when i went to order, cosworth were only sold in pairs. Roughly mid 200$ range so 260$ sounds correct.
cometics DO have the full stopper ring. I have 2 used sets i have removed from my engines and they have the stopper rings in them. I also have an unused set of HR gaskets (i wanted to use them then damaged my block so I just bought an assembled shortblock) and they have a stopper ring as well.
as for machining. The machine shop just used a dremel to open the passages. Had i known this i would have saved myself 60$ and done it in my garage. Since i ordered a new assembled short block I did not want to tear it down to cut out the passages so I just used cometics again.
From all the testing that shariff did and posted on here it appeared that the problem with head lift and pushing air into the cooling system wasn't an issue with head gaskets as much as it was an issue with the clamping force of the studs. Proper clamping force will greatly maximize the pressure a head gasket can be subjected to.
Maybe i'm a cheap *** but i've never had a single issue with a cometic gasket and won't ever stress that my cometic gasket will fail under NORMAL conditions at any power level that my rods could hold. Detonation, etc, is a different story. Just as well, i don't think the HR gasket would have any issues based on other that use it and if i could have cut my block i would have used them.
I plan on pushing this setup to 800hp without fear of HG failure. I also only used 80ftlbs on my L19's instead of the "recommended" 90ftlbs that people use on here. ARP actually says to only use 80ftlbs with their instructions that are included. I also pulled out 2 head studs from the block when trynig 90ftlbs. My snap on torque wrench is calibrated yearly and i'm confident it works properly. Maybe there was a problem with my block. I don't know and didn't want to risk it again.
So far, 80ftlbs, cometic gaskets, 650hp, coolant levels haven't increased or decreased and no air in the cooling system.
Old Jan 15, 2012 | 05:39 AM
  #38
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
For anyone set on Cosworth, Dynosty can do Cosworth head gasket sets for $199/set shipped! Call to order, 859-230-9027
lapham3
Oct 7, 2022 03:15 PM
Justin100
Nov 25, 2021 06:26 AM
3vilbunny
Jul 18, 2017 05:10 PM
