Carbonetic Triple Clutch Question
Old Jan 23, 2012 | 06:37 AM
RED RIDER's Avatar
RED RIDER
Originally Posted by psychoballistic
Off topic quick, but before you bolt everything back up, make sure to check the throw so that it will engage the pressure plate. I have a side by side of the two sleeves that I may or may not have sent you. I use the Nissan TO and sleeve that Carbonetics suggest which I believe is for the Xterras, and have had ZERO issues. I'll send you the photo of the difference in sleeves if you want.
If my thickness is still good, I think i'll put it back in and try it. Once I have the specs, i'll check everything with the micrometer this weekend. I feel better knowing that others do have heat markings though.
I think we went over this before but DEFINITELY send me info on the TO you are using....I would like to see it..
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
