Problem when shifting under boost
Old Jan 24, 2012 | 12:52 PM
init's Avatar
init
Default Problem when shifting under boost
Quick run down, got momentum turbo kit installed a few months ago, clutch started slipping because of the power so I got a new clutch put in, everything was fine until about 2500 or so miles with the new clutch. When I shift as if I am racing the car it seems like the clutch or engine sputters not sure which, I have to let off the gas for a second after I shift then the car goes just fine if I stay on the gas while heavy acceleration it sputters for a second, the shop says I have a bad ecu do you guys think that can be an ecu problem? It only happens during hard acceleration other then that the car runs just fine
Old Jan 24, 2012 | 12:57 PM
init's Avatar
init
And there is no vacuum leaks btw
Old Jan 24, 2012 | 01:42 PM
Cass007's Avatar
Cass007
Getting this moved to F/I...
Old Jan 24, 2012 | 02:11 PM
ace32x's Avatar
ace32x
sounds like a missfire to me, getting any codes?
Old Jan 24, 2012 | 03:30 PM
str8dum1's Avatar
str8dum1
what ems is this tuned on? Quite possibly you are getting shift knock, which is killing the timing.
Old Jan 24, 2012 | 05:03 PM
init's Avatar
init
its tuned with uprev, the car has been doing this for a few weeks so i had time to take it to the shop today, but yesterday it threw a p0507 code which is with idle
Old Jan 24, 2012 | 05:34 PM
init's Avatar
init
http://www.youtube.com/watch?v=HoVBU...endscreen&NR=1 if you go to 2:44 - 2:46 you can hear what the car does
Uriyo_
Sep 8, 2021 08:46 AM
