Aem ems
Old Feb 17, 2012 | 12:13 PM
ctadashi09's Avatar
ctadashi09
Default Aem ems
Currently Working on my Greddy Twin Turbo build for my 03' 350z. I wanted to get some input on which EMS to use.
I know that it would be recommended to use a Haltech or F-Con Vpro EMS for a proper tune, but the shop I am working with is suggesting the AEM EMS. The reason they recommended the AEM over the Haltech is that their tuner works for AEM and actually helps build the EMS so he knows the system inside and out.
I know the AEM EMS is universal and not necessarily compatible or PnP with the 350z without some modifications. So my question is, should I go with a lesser EMS that might be more work to use, but the tune will be excellent coming from an actual AEM tuner? Or go with a haltech or F-Con Vpro that the shop tuner may not be completely familiar with?
Old Feb 17, 2012 | 12:24 PM
Glex25's Avatar
Glex25
You should think about it like this.
What happens if you move out of the area will someone else be able to work with the AEM ems as easily as your current tuner if at all?
What happens if you need to go back to the stock EMS or something else would you have to rewire your harness?
How much support apart from the person you are dealing with is there for that ems in your current platform?
Personally I rather deal with something that the masses are using and proven if I have any questions or need to troubleshoot later on down the line.
Old Feb 17, 2012 | 12:28 PM
ctadashi09's Avatar
ctadashi09
I doubt I will ever move from California but I completely get your point.
I can still get the Haltech or F-Con VPro but should I worry about the tuner's ability to use other EMS?
The guy apparently heads AEM's EMS tuning so I figure he should be knowledgable enough to be able to work with other EMS.
Old Feb 17, 2012 | 12:32 PM
wannabuy350z's Avatar
wannabuy350z
in order for the AEM to work and especially take full advantage of your kit like intake cam timing. you will need to do modifications to the engine.
please tell me the name of the shop that is suggesting this. I used to live in Cali
PM if you like
Old Feb 17, 2012 | 12:39 PM
ctadashi09's Avatar
ctadashi09
Pm sent
Old Feb 17, 2012 | 12:44 PM
rcdash's Avatar
rcdash
Keep in mind Haltech has 2 options now - piggyback and full standalone. Both employ a very end user / tuner friendly interface. Your AEM tuner will have no trouble setting up a Haltech.
http://www.dynosty.com/2012/01/new-h...u-replacement/
Also note that AEM has a brand new EMS in the works. Not sure if your tuner is recommending the new version or the old. A significant expense to consider will be a custom harness for your car if one does not exist, so be sure to check on that.
Old Feb 17, 2012 | 12:45 PM
ocdz's Avatar
ocdz
I am fairly certain aem has a plug and play option for nissan. so at the very least you won't be splicing wires.
Old Feb 17, 2012 | 12:49 PM
ctadashi09's Avatar
ctadashi09
my friend is selling his slightly used F-CON VPro w/ navigation for $1,000 so i was wondering if that would be a good route to go?
Old Feb 17, 2012 | 12:51 PM
Glex25's Avatar
Glex25
To tune a Fcon the tuner will need a key to access it.
It is a closed system and unless someone is a Fcon tuner paying for a key is very expensive
Old Feb 17, 2012 | 12:59 PM
ctadashi09's Avatar
ctadashi09
Asking my friend right now.
so far he just told me its a FCon Navigator and FCon VPro 3.0 with all harnesses and sensors for Map and Air Temp.
Old Feb 17, 2012 | 01:03 PM
ctadashi09's Avatar
ctadashi09
Update: the shop/my friend doesnt have a key so going for haltech
Old Feb 20, 2012 | 02:35 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
^ Good choice. Give us a call if you want to get in on the Haltech Pro Plug-In (complete stock ECU replacement) preorder. They will be arriving soon!
bcoffee20
Nov 19, 2015 06:39 PM
350Shadow
Sep 22, 2015 08:30 AM
Obeorangekenobi
Sep 11, 2015 07:17 AM
