Twin Charging my Z!
Old Apr 16, 2012 | 06:13 AM
  #261
SuperZ-onDPE's's Avatar
SuperZ-onDPE's
done with the project. just need to dyno tune
Old Apr 16, 2012 | 06:21 AM
  #262
Quamen's Avatar
Quamen
Looking good! Just remember that compound boost is multiplied rather than added. In for results.
Old Apr 16, 2012 | 04:21 PM
  #263
4SHIZZIL's Avatar
4SHIZZIL
Yeah prob close to 30psi!
Old Apr 17, 2012 | 11:05 AM
  #264
SuperZ-onDPE's
only had one scare. the oil pump for the turbo was routed back words lol. but it was fixed.
as for boost im keeping my eye on the boost guage real good till were done.
i think i do my wide band tommorrow, maybe this weekend i get some tune time.
things i had to "mod" were, fuel rails... we had to grind them a bit on the brackets. cuz the plenum would not seat all the way.
and intercooler mounting brackets for the water/air sc cooler. it sits infront of the turbo intercooler now.
i recoreded 20GB of video. im going to put a video together on how it was done. it includes super and turbo install injectors and some other stuff like oil lines and pumps.
Old Apr 19, 2012 | 10:21 AM
  #265
SuperZ-onDPE's
driving normal with out boosting im reading 29-35MPG. still need to do some test on the accuracy on the readings. ive driven over 250km.
Old Apr 19, 2012 | 12:32 PM
  #266
djamps's Avatar
djamps
If you changed your injectors then the MPG 'reading' is way off.
Old Apr 19, 2012 | 01:31 PM
  #267
Flo-ridaZ33's Avatar
Flo-ridaZ33
Mine says I'm at 35mpg and I'm only getting 200 miles per tank.
Old Apr 19, 2012 | 05:15 PM
  #268
4SHIZZIL's Avatar
4SHIZZIL
Fav thread !
Old Apr 19, 2012 | 06:21 PM
  #269
dj lizard's Avatar
dj lizard
damn I was fallowing this thread from page 1.... The concept is great but I would love to see some dyno results and vids or at least pics for the PL and stillen setup... I wonder how it spools up and the sound might be like a rocket lol.
Old Apr 20, 2012 | 06:39 AM
  #270
TopgunZ's Avatar
TopgunZ
I know! Trust me I want to get this thing on the dyno and see what happens. I just have a busy lifestyle and its going WAY slower than I had hoped. Trying to cram all that under the hood is a beotch. The turbo is in and all under the car work is done except I have to build a Y pipe. I still need to hit a junkyard to find a tiny washer fluid reservoir as there is no way my oem will fit. The SC is back on. Oil cooler, and guages are still laying on the floor and I need to get a long return fuel line made up and custom build a few brackets since I relocated just about everything.
Super Z's car is on the road. Props to him for his quick build and dedication. I cant beleive he has put on 200 miles and hasnt got it on the dyno. That is some serious will power there. Im going to be putting mine on a flatbed my buddy has to get it to the shop so i wont foul my plugs on the way there. My original plan was to have this done early to mid april but unforseen events occured....and her name is Ashly.
I have an open dump going on right now but have been indecisive on if i want it recirculating.
What are your guys thoughts on this?
Old Apr 20, 2012 | 06:50 AM
  #271
dj lizard's Avatar
dj lizard
I't a new idea and it's hard to get info on it over here. I know that for sure. the 2 twin charged z on the road now that I have seen are SuperZ and the one on the vid. If you have the money to do it then why not... that's opinion.. will the recirculated will be a bit restrictive, go with the open dump pipe..
Old Apr 20, 2012 | 08:38 AM
  #272
ace32x's Avatar
ace32x
because no one wants to spend the money to buy 2 kits to make this happen, interesting idea to say the least tho
Old Apr 20, 2012 | 10:19 AM
  #273
Nismomonkey's Avatar
Nismomonkey
thoroughly interested in pics/vids/dyno sheets
Old Apr 20, 2012 | 10:45 AM
  #274
djamps's Avatar
djamps
will the skinny stillin belt hold up to the compound charging? Surely the compressor will be working harder..
Old Apr 20, 2012 | 11:16 AM
  #275
IDrm350's Avatar
IDrm350
Quite the opposite actually. The turbo is force feeding it air making the supercharger's job easier.
Old Apr 20, 2012 | 11:18 AM
  #276
TopgunZ's Avatar
TopgunZ
The only way that it wouldnt is if it spun faster. Otherwise there isnt any added stress on it. With my 6lb pulley it will spin slower than before so it should last even longer. Which raises a question. When I want more boost...Do I put the 8.5lb pulley back on or do I tighten the wastegate? Hmmmm.......
Old Apr 20, 2012 | 05:28 PM
  #277
4SHIZZIL's Avatar
4SHIZZIL
Stillen will max out what it can ingest, no clue ow to find that out, but id start w turbo increases first
Old Apr 20, 2012 | 09:32 PM
  #278
Quamen's Avatar
Quamen
Definitely start with the turbo. Again, if you don't realize that compound boosting will multiply boost then you will be suprised when +2.5psi is actually significantly higher.
Old Apr 23, 2012 | 04:30 AM
  #279
SuperZ-onDPE's
like i said, more test stilll need to be done.
Old Apr 23, 2012 | 04:33 AM
  #280
SuperZ-onDPE's
sounds nothing like a rocket. spool is crazy. punch the throttle and super is launching the car. few rpms later you still feel the sink in to the seat as the boost guage is still climbing. its nice. i promis youd love it if you had it.
