copy sts kit but not making boost HELP
Old Apr 1, 2012 | 07:47 PM
mattyg's Avatar
mattyg
Default copy sts kit but not making boost HELP
so I ran all the charge pipe and oil lines with pump but the problem I'm having is I'm still not making boost any ideas
Old Apr 1, 2012 | 10:13 PM
hellsoldiers08's Avatar
hellsoldiers08
leak??? and wait so your coping the sts kit?
Old Apr 1, 2012 | 11:41 PM
GraysZ's Avatar
GraysZ
Is your turbo is spooling? It would be nice if you could provide more information of your build etc. What makes you think your not making any boost? Recheck your plumbing and joints for vac/boost leaks and also check your wastegate if its stuck open or has weak springs.
Old Apr 2, 2012 | 05:15 AM
djamps's Avatar
djamps
Make sure the blinker fluid is topped off. Also change the muffler bearings.
Old Apr 2, 2012 | 05:42 AM
huyrua's Avatar
huyrua
Turn on the flux capacitor first.
Old Apr 2, 2012 | 06:29 AM
athenG's Avatar
athenG
What size is your turbo especially the hot side? You cant just plug in any turbo especially big turbo and expect to make it work
Old Apr 2, 2012 | 12:48 PM
jerryd87's Avatar
jerryd87
do you hear it even spinning? when my car wasnt dead i heard the 6765 spinning up far before it made boost, even light throttle.
Old Apr 2, 2012 | 01:02 PM
ace32x's Avatar
ace32x
dead? what happened already lol
Old Apr 2, 2012 | 01:47 PM
Cass007's Avatar
Cass007
Old Apr 2, 2012 | 01:48 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Not enough info to really say, but I'd GUESS that you've got a boost leak.
Old Apr 2, 2012 | 05:51 PM
jerryd87's Avatar
jerryd87
well after getting a used one today it appears the ipdm went bad on it since my problems are solved and just got it running again. although i sold my wheels to pay for the machine shop since ive been back a month and still have not gotten my per deim after submitting it 4 times. prob should waited and payed off bill with per deim lol.
Old Apr 2, 2012 | 06:53 PM
mattyg's Avatar
mattyg
ok I got a 50 trim hot side 1 1/2 charge piping ssqv bov and i switched the spring to a 7 lbs but it seams the waste gate hasn't even opened also it spools like crazy so I don't think that's the problem but I do still have the stock headers and cats so i can always delete them if it's not flowing enough but I really don't think flow is the problem idk maybe my bov is not sealed all the way that's the only thing I haven't tested and I'm starting to think the charge pipe may be to small tomorrow I'm going to remove the bov and just put a peace of pipe in and see if I boost other the. that I have no idea
Old Apr 2, 2012 | 08:09 PM
jerryd87's Avatar
jerryd87
50 trim dosnt say a whole lot about the turbo but if its like the ones the dsm guys run and srt4 guys run that im seeing in the google search you wont make boost on that turbo. since the amount of air it flows it would have a hard time even keeping up with the engine with a t3 backside that they all seem to have.
your probably boosting 1 mayby 2 lbs, which is being lost to pressure drop from all the piping, and thats the max your going to get from that turbo.
that is if your running the turbo i found on google, dint give really any details since trim refers to the wheel, more specifically a numbered trim refers to compressor wheel. turbine trim will be a letter, and the turbine A/R is just as important as the other two pieces of information.
also is it a true ssqv from hks or a knockoff on ebay? if its a knockoff its probably leaking since the ebay ones seem to have tons of problems, the tial style ebay ones are the ones that are ok. 1.5 inch charge pipe is probably too small but its hard to determine since air flows differently when compressed but you should have 2 inch just to be safe.
Old Apr 2, 2012 | 08:14 PM
Barnabas's Avatar
Barnabas
National Z Club President
I can see where this is going. This will be good.
In to see what happens
Old Apr 2, 2012 | 08:19 PM
jerryd87's Avatar
jerryd87
oh yah a extra little bit again going off what i find off google since you gave little details and all the "50 trim" turbos i find are the about he same in airflow, minus the billet ones. This turbo is equal to a 16G turbo, why on earth would you think you could make any more power then stock when people running TWO 18G turbos are at 500-700 whp? thats with TWO, of a BIGGER turbo. i feel like im being punked here
Old Apr 3, 2012 | 04:44 AM
djamps's Avatar
djamps
Have you tried this:
Old Apr 3, 2012 | 06:47 AM
mattyg's Avatar
mattyg
so what turbo do you think I should run man
Old Apr 3, 2012 | 07:21 AM
konrad's Avatar
konrad
At least a 60-1 or Hx35 or hx40
Old Apr 3, 2012 | 11:16 AM
Cass007's Avatar
Cass007
Run-on sentence
A run-on sentence is a sentence in which two or more independent clauses (i.e., complete sentences) are joined without appropriate punctuation or conjunction. It is generally considered a stylistic error, though it is occasionally used in literature and may be used as a rhetorical device. An example of a run-on is a comma splice, in which two independent clauses are joined with a comma without an accompanying coordinating conjunction.[1][2] Some prescriptivists exclude comma splices from the definition of a run-on sentence,[3] though this does not imply that they consider comma splices to be acceptable.
Old Apr 3, 2012 | 12:09 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Originally Posted by Cass007
Run-on sentence
Oh that is just great!
