Question? Cosworth spacer
Old Apr 7, 2012 | 06:05 PM
sradenton's Avatar
sradenton
Default Question? Cosworth spacer with GTM stage5
Sorry for SUCH a NOOB question, but I been searching and cant find the answer. I have a GTM stage5 being install on my 2005 350Z and spacers have been install to raise the engine to clear the turbos and Im thinking if I use the cosworth spacer it will hit the hood. Does anyone know if this is tru? or can I get by not using it?
Old Apr 7, 2012 | 06:41 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
The Cosworth spacer is used with the Cosworth intake. This is done so larger, after market injectors can fit with the Cosworth intake. No Cosworth intake, no need for Cosworth spacer.
BTW: spacers to raise the engine???
Old Apr 7, 2012 | 07:16 PM
sradenton's Avatar
sradenton
I have the cosworth Manifold and yes the kit came with spacers to fit the
Gt3082r turbos
http://www.gtmotorsports.com/product...cat=551&page=1
Guess I have no choice but to use the cosworth spacer also.
Thank you for the answer
Old Apr 7, 2012 | 09:40 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
I think you should have lots room. I don't have the motor mount spacers but with the cosworth spacer I can still fit a strut tower brace so you have a good 2" before the motor mount spacers, and the cozi spacer is required with most if not all after market rail and injector set ups.
Old Apr 8, 2012 | 01:10 AM
sradenton's Avatar
sradenton
Nice!!! 2" inches didnt think there was that much. Should be no prob. Then. Thank you, for the good advice.
issyz
Jul 2, 2017 03:04 PM
