Rev-up vs Non-rev up for Twin Turbo Build with Built Short Block
Old Jun 11, 2012 | 08:43 PM
clubhopper's Avatar
clubhopper
Default Rev-up vs Non-rev up for Twin Turbo Build with Built Short Block
Hi,
I've been debating using a rev-up motor or non-rev up motor for a TT build. Maybe some of you have seen my other thread in 'Engine and Drivetrain' regarding differences between a revup and non-revup.
My car is an 06' MT so therefore its has the stock revup ECU and Harness. I'm now aware of the differences between a revup and a non-revup physically and how they perform.
However, I have a question that maybe the experts can chime in on as i've searched on this and couldn't find a definitive answer.
I will be using Haltech's new standalone pro plug-in OEM replacement ECU to run the engine (which if I understand correctly, means I can use either a revup or non-revup in my car regardless of the harness) - is there any compelling reason that I should use a rev-up motor and boost it vs using a standard DE motor and boosting that?
Performance wise will the inherent differences between a DE and DE revup be so insignificant under a boosted application that going either way (revup or non-revup) wont even matter at that point?
I'm asking this because I currently have in my possession every part, cam, gear, bolt, nut, screw, gasket to make up a full VQ35DE non-revup. But i intend to put it in my revup based car.
Thanks very much in advance!
-Ning
Old Jun 12, 2012 | 01:59 AM
konrad's Avatar
konrad
Besides the fact you can tune the exhaust cam timing and maybe spool a little faster and make some more power I think its all the same. ( most tuners wont even touch cam timing)
There are more cam options for the non rev up tho.
Old Jun 12, 2012 | 06:59 AM
eltness350's Avatar
eltness350
The Untouchable
i would keep it the same, a few have tried doing what your suggesting and seem to have electrical issues with stuff not working/performing correctly...the non rev de will give you a little more tq down low but when you has twin turbo it dont matta!
Old Jun 12, 2012 | 09:23 AM
eZg's Avatar
eZg
[QUOTE=
There are more cam options for the non rev up tho.[/QUOTE]
This is what I was thinking Wat is it the BC2's That everyone really likes?
