vortech supercharger cog belt slip.
Old Jun 25, 2012 | 07:09 AM
Calinismo350z's Avatar
Calinismo350z
Default vortech supercharger cog belt slip.
hey everyone, how was the weekend.? has anyone had isues (belt slip) on the supercharged drive belt?? the reason of this it's because I had my supercharger installed about a month ago and this weekend when I went to the track my supercharger belt slipped and rip. I was pretty upset cause I was taking a cherokee srt8 . Now the tooth from the cog pulleys seem like they damaged, does this means I have to replace the cog pulleys?
Old Jun 25, 2012 | 07:37 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Jun 25, 2012 | 08:21 AM
tonyzS/C03's Avatar
tonyzS/C03
HUH? got pictures? if it was the cog belt that "slipped" you have got a serious issue. the other larger serp belt is prone to slipping especially in the higher RPM's... search for the TimRod pully mod or the GTM pully mod for a good starting place to fix the issue.
Old Jun 25, 2012 | 08:22 AM
Calinismo350z
moved..?? you meant the belt was moving.
350zhp306's Avatar
350zhp306
I would take a picture so that we can see how much damage was done on the cog pulley. I also have an unused 28 tooth cog that I would be willing to sell cheaper than if you were to buy from Vortech.
Old Jun 25, 2012 | 08:25 AM
Calinismo350z
yeah the cog belt. I'm not sure if slip was the issue or just that the belt ripped. il try to upload some pictures later on since right now I'm at work and I don't think I can upload them with my phone.
Old Jun 25, 2012 | 08:28 AM
suprasam's Avatar
suprasam
Vo is a Moderator and moved it to the correct forum sub group because you must have posted in the incorrect group.
Old Jun 25, 2012 | 09:23 AM
Calinismo350z
I'm most likely gonna need to buy them new. PM me .
Old Jun 25, 2012 | 10:04 AM
Lee R's Avatar
Lee R
Why don't you just contact Vortech customer service directly?
Hours of Operation
Monday - Friday: 7:00 am to 3:30 pm PST
Phone
805-247-0226
Old Jun 25, 2012 | 10:37 AM
- bigc -'s Avatar
- bigc -
if your cog belt shredded then thank your lucky stars you didn't do some serious damage.
Old Jun 25, 2012 | 11:02 AM
tylerxfire's Avatar
tylerxfire
check ur sensors around that area and hope they are ok, most people with this issue end up ****ing other things up...
Old Jun 25, 2012 | 11:38 AM
Calinismo350z
yeah it did shredded in fact that's the first thing I checked .. but I've been driving the car with no belt and everything sounds good.. I'm gonna stop at napa see if they have the belt, I'm gonna put it on and double check the belt runs good.
Old Jun 25, 2012 | 12:09 PM
kartkid's Avatar
kartkid
good luck at Napa but if the belt shredded it was not from slipping it would be more from being over tight.
the belt you need is a (Gates Power-Grip GT-2 6008MGT20)
Old Jun 25, 2012 | 12:20 PM
Calinismo350z
yeah that's what vortech told me. that it was over tight. thanks for the help I really appreciate it.
Old Jun 26, 2012 | 01:43 PM
jpc350's Avatar
jpc350
I vote for it having been tooo loose...When you install a replacement, try to install it where you just about have enough tension in it where you just about can rotate the pulley it wraps around..When the car has been running and warmed up, you should not be able to rotate the same pulley..
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
