Injectors with 20G TT setup
Old Sep 5, 2012 | 01:51 PM
zmego1999's Avatar
zmego1999
Default Injectors with 20G TT setup
I have a 2003 Z with:
20G GReddy Twin turbo kit
custon downpipes
High flow cat
3.5 exhaust
GReddy front mount
255lph fuel pump
Osiris Flash
I need injectors. I found 720cc Denso injectors on eBay for a good deal. What are your thoughts? The car is getting tuned at the end of the month.
Peter
Old Sep 5, 2012 | 02:46 PM
Ruthless18x's Avatar
Ruthless18x
Can't speak for the ones on eBay but 720's are plenty stock block.
Where did you put the cat?
Old Sep 5, 2012 | 04:49 PM
Cass007's Avatar
Cass007
moved
Old Sep 5, 2012 | 06:03 PM
Escobar's Avatar
Escobar
what are your hp goals? Are you running a fuel return system? Stock block?
Old Sep 6, 2012 | 07:08 AM
tonyzS/C03's Avatar
tonyzS/C03
Old Sep 6, 2012 | 10:53 AM
f150intally's Avatar
f150intally
I will make you a good deal on 600s or 850 Deatschwerks that will drop in. PM me.
Old Sep 8, 2012 | 05:17 PM
binder's Avatar
binder
You won't need anything larger than 600cc injectors on a stock block. They will provide more fuel than the block will handle for power.
Get some quality injectors or the tune will be a nightmare and the car won't run smooth. Injectors are money well spent. DW makes great 600cc injectors.
Old Sep 8, 2012 | 11:13 PM
wannabuy350z's Avatar
wannabuy350z
i recommend getting ID1000cc injectors. regarding your fuel system its never a bad idea to leave room for future upgrades.
Old Sep 9, 2012 | 03:32 PM
binder's Avatar
binder
way overkill unless a person is planning on building. ID makes great injectors so I would recommend the 750's for him. Even built block they will push enough fuel for close to the limit of 93 octane.
Old Sep 10, 2012 | 09:09 AM
zmego1999's Avatar
zmego1999
It is a stock block. Nothing is done internal. All bolt ons. I ordered the 720's. The cat is gone. Now I am looking for wheels.
Old Sep 13, 2012 | 05:59 PM
Domer74's Avatar
Domer74
Id725s is what I am running.. Got em here
http://www.turbosource.com/ID725-p/ts4-08-75000.htm
