to start up or to not start up(vortech)
Old May 17, 2013 | 12:20 PM
Sequence's Avatar
Sequence
Default to start up or to not start up(vortech)
I have nearly completed my vortech build on my 06 rev-up Z. 255 fuel pump, 570cc injectors, v2 sc-trim w/3.12, treadstone tr8L fmic, mrev 2 & spacer, test pipes, true dual exhaust. I will be taking the car to have it dyno tuned, but my question is, before I take it in, can i fire her up to make sure she's running? or is that a really BAD idea without any tuning? I ask this question because I don't want to tow it to the shop to find out it won't even fire up and then tow it home to figure out what the problem might be.
thanks
Old May 17, 2013 | 03:40 PM
str8dum1's Avatar
str8dum1
you can start it and drive it all you want out of boost with absolutely no issues
Old May 17, 2013 | 04:36 PM
Sequence's Avatar
Sequence
ok great. thank you for the response!
Old May 17, 2013 | 07:49 PM
DFW Adrenaline's Avatar
DFW Adrenaline
Just stay out of boost and you will be perfectly fine
Old May 17, 2013 | 07:51 PM
bealljk's Avatar
bealljk
If it was me I would absolutely start it up - you want to resolve any issues so that your tuner can tune…I would let it idle and have a good look in the engine bay and make sure everything is operating as it should…I would then take it out for a few miles of easy (no boost) operation…get back home and let it idle down and do another look over of the engine bay…you want to put yourself in a position to be able to tune…you don't want your tuner adjusting belts, tightening bolts, moving hoses, etc...
Old May 18, 2013 | 11:20 AM
Sequence's Avatar
Sequence
awesome. that is exactly what i was hoping that i could do, but wanted to make sure first.
thank you.
Old May 18, 2013 | 07:01 PM
hellman_x's Avatar
hellman_x
Just take off the cog belt and don't drive it too hard.
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
Dymsi
Sep 29, 2015 11:32 AM
