Boost reference on HR?
Old Aug 3, 2013 | 10:59 AM
AT1222's Avatar
AT1222
Default Boost reference on HR?
Where can I get a vac/boost reference on my 07 z for my bov, boost gauge, and boost controller? And can I t them or should I run seperate lines? Thanks!
Old Aug 3, 2013 | 12:14 PM
BigBlue's Avatar
BigBlue
I have a sc kit on my '07; the vac. line that I T'd into for boost gauge runs from bypass valve (don't have a bov) over the top to the rear of engine where it T's into a brake booster line; I T'd into that new line so 2 T's near each other on seperate lines; the new line came with the Stillen kit.
Old Aug 3, 2013 | 10:02 PM
kloudak47's Avatar
kloudak47
I taped on the back side of the manifold and put an npt barb in. I then ran tubing from here to my bpv.
If you tap, make sure you do it with the manifold off so you dont dump any plastic shavings inside the engine.
Old Aug 4, 2013 | 09:40 AM
AT1222's Avatar
AT1222
Thanks guys, I will probably tap the plenum then.
Also, I was told that I need to put "check valves on the 2 pcv lines that connect to the plenum". Does anyone know where I can get these check valves and exactly where to put them on an hr?
codek
Sep 28, 2015 03:03 AM
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
Detailed Image
Sep 16, 2015 04:56 AM
