FS: Momentum Turbo Kit GT35r jet hot coat
Old Oct 27, 2013 | 09:47 AM
Skeptikal's Avatar
Skeptikal
Default Momentum Turbo Kit GT35r jet hot coat
Selling a Momentum Turbo Kit. These are becoming very hard to find and most will agree these were the most well put together kits for the Z. The kit is not complete though and sold AS IS. Will need injectors, intercooler, air filter, blow off valve, silicone coupling from throttle body to crossover pipe, and crossover pipe itself (pipe that goes from throttle body to passenger side intercooler pipe). I'm sure the pipe from the powerlab kit would work, or the guys from national speed could supply something no doubt.
MAF sensor, 1 water coolant line that runs to turbo, and a.c. line (can get from National Speed). Everything else is here (clamps, couplings, bolts, feed and return line, etc.).
Turbo has no shaft play. I realize the kit is incomplete hence the low price so I am not willing to negotiate much further. Thank you.
1,700 + 100 for shipping anywhere in U.S via FedEx ground!
Old Oct 27, 2013 | 04:39 PM
Nino135's Avatar
Nino135
I'm guessing it's for a DE?
Old Oct 27, 2013 | 05:38 PM
Skeptikal's Avatar
Skeptikal
correct, but will fit rev up models as well. years 03-06.
Old Oct 27, 2013 | 06:40 PM
Nino135's Avatar
Nino135
#HRproblems lmao
Old Oct 28, 2013 | 11:36 AM
monsta24's Avatar
monsta24
Is the crossover pipe (exhaust) missing? I don't see it in your pics...
Old Oct 28, 2013 | 11:44 AM
Skeptikal's Avatar
Skeptikal
Yes that's included, look close (top right of picture) it's there.
Old Oct 30, 2013 | 02:09 PM
dannydrummer14's Avatar
dannydrummer14
Manifold included?
Old Oct 30, 2013 | 02:18 PM
Skeptikal's Avatar
Skeptikal
Originally Posted by dannydrummer14
Manifold included?
Exhaust manifolds? If that's what you're referring to no.
Old Nov 7, 2013 | 05:22 PM
Grigsbybear350's Avatar
Grigsbybear350
Can you run the stock manifolds with this kit?
Old Nov 8, 2013 | 03:46 AM
Skeptikal's Avatar
Skeptikal
Yes you can run oem manifolds.
Old Nov 20, 2013 | 05:33 PM
Skeptikal's Avatar
Skeptikal
SOLD.
