Vortech gurus. Enter... 928m impeller. Shredded :-(
Old Nov 18, 2013 | 02:34 PM
the3kgt2's Avatar
the3kgt2
Originally Posted by Colombo
What size is the fluidampr in inches?
Fluidampr is 6.125" versus stock 5.75"
Old Nov 18, 2013 | 02:56 PM
OldManZ350's Avatar
OldManZ350
Hay Johnattan,
Can you Verify your Serp and Cog Setup?
Fliudamper looks like it's 6.50 od, based on this with a 2.87 serp and a 28/32 Cog you would be spinning your Blower over 69,000rpm.
That being said, I spin my Blower to 62355rpm without any problems so far. I do drag race some, but No track or autocross. This is as hard as I'm willing to push the stock street blower.
Attached Thumbnails Vortech gurus. Enter... 928m impeller. Shredded :-(-screen-shot-2013-11-18-at-6.42.13-pm.png
Colombo's Avatar
Originally Posted by jerryd87
by there own words "almost" 1200 cfm at 50k vs the one old man posted of 1400 at 55k. its not like its some brand new start up company there isnt a "being a guinea pig" you should know not many people go super charger for big power. if you have questions its best to use google, just because it might be on a different car it will still perform the same way.
edit: old man posted while i was typing.
by guinea pig i ment for the Z. i have seen 1 other z running this blower and its located in lebanon. its the 1 on the vortech site. any other google search yielded nothing. the info vortech has up is minimal. built motor blower 600 hp. basically thats it. also tim i thought noone has had sucess w the YSI as of yet? if this v1 TI is the answer for 600 RELIABLE HP that can be pushed to 7400 RPM with a 2.87 pulley (setup w everything i am currently running) im pretty much sold on it ill jump in just to be different. i just wish there was more people out there running this setup or atleast more info on the 1 that is out there.
Old Nov 18, 2013 | 02:57 PM
Colombo's Avatar
Originally Posted by OldManZ350
Hay Johnattan,
tim i am on stock cog setup so 32/28 for v2 SC trim to my understanding.
Old Nov 18, 2013 | 03:07 PM
OldManZ350's Avatar
OldManZ350
You would Not need to Spin the V1-Ti Trim to the Same Rpm…..
I think you could spin the blower 4-5000rpm slower and make More Hp….
There are successful V7-YSi's out there making well over 700Whp
Old Nov 18, 2013 | 03:08 PM
the3kgt2's Avatar
the3kgt2
Hay Johnattan,
The fluidampr is 6.5" outside diameter, but it's 6.125" across where the belt makes contact to the pulley. That's at least what I've heard and read. You should be entering 6.125" in the calculator
Old Nov 18, 2013 | 03:10 PM
OldManZ350's Avatar
OldManZ350
Can you Verify?
Below is the info I got.
Attached Thumbnails Vortech gurus. Enter... 928m impeller. Shredded :-(-screen-shot-2013-11-18-at-7.08.12-pm.png
Old Nov 18, 2013 | 03:12 PM
the3kgt2's Avatar
the3kgt2
Can you Verify?
That's just outside diameter of the entire pulley. You need to measure inside diameter, where the pulley actually makes contact.
https://www.google.com/#q=fluidampr+...ite:my350z.com
Old Nov 18, 2013 | 03:20 PM
Colombo's Avatar
Sorry for your loss. It was a beast while it lasted.
I believe the 2.87 pulley with fluidampr crank pulley puts your blower at 65,156 rpm when revving to 7400rpm. No bearing could hold that.
You're also exceeding 928m's max rpm rating for the impeller too:
"Each impeller is spin balanced to 0.006 grams/inch, and designed to operate up to 60,000 rpm"
3kgt2 where did u get this number? just trying to figure out what i would be spinning the v1 at if i ran this setup.
Hay Johnattan,
not sure if its 6.50 tim i just went outside and its very very close to 6in maybe 6.1 deff no where near 6.5 from what ii can tell on the car
OldManZ350's Avatar
OldManZ350
I Understand That!
I was hoping to see Numbers Verifyed from Fliudamper.
The only place 6.125 shows up is on my350.com
Old Nov 18, 2013 | 03:22 PM
Colombo's Avatar
i was told ID on the fluidampr is same as stock. honestly measuring from the center bottom of the pulley where the tape measure can grab the outer lip to the top outer lip its maybe 6.1 but inner diameter where the belt touches i would say it could be same as stock 5.7 ill try and get a picture
the3kgt2's Avatar
the3kgt2
I Understand That!
Click the link. A couple members actually measured it and they both came up with 6.125"
Old Nov 18, 2013 | 03:24 PM
the3kgt2's Avatar
the3kgt2
Originally Posted by 350z006
I re-did the measurement on my newly acquired Fluidampr to compare it to the same 5.75 measurement point on the stock pulley (which is where it mounts the belts) and I measured 6.125, the same as you got from Fluidampr...I'm not sure why they told me 6.25 when I called them
Taken from 350z006
Old Nov 18, 2013 | 03:27 PM
Colombo's Avatar
ok deff cant get a decent phone shot but its deff not 6.5 ID 6.5 outer diameter prob but from what it looks like maybe 6.1ish ID diameter obviously on car thats best i can guess.
Old Nov 18, 2013 | 03:40 PM
OldManZ350's Avatar
OldManZ350
The V1 and V7 have a different Step up Ratio of 3.45/1 vs 3.61 of the V2 and V3
So, the V1 and V7 4.2% Slower, with the same Serp and Cog setup.
I'd start with the 3.12, that will spin the blower 59935-4.2%+=57388rpm. And see how that works for you.
The V1 Ti-Trim is rated @ 55,000rpm
The V7 YSi-Trim is rated @ 65,000rpm
What is your Fuel System Setup?
Old Nov 18, 2013 | 03:46 PM
Colombo's Avatar
did the calculator on vortechs site for the v1 and even spinning to 7400 rpm that blower rated to 55000 rpm hits 54484.76 at 7400 rpm w the 2.87 pulley. any idea what kinda boost that blower should hit at those rpms w that pulley. i know that is a random question. im going to think it all over once i pull this blower. 3k is enough money to maybe pick up a turbo setup or atleast most of it considering i do not need a fuel setup or intercooler since mine is pretty solid along w motor.... really not sure what im gonna do but i thank you all for the information. such a good feeling to know i can turn to most of you guys when something like this happens to help me threw my questions. Tim i may be messaging you/ emailing you with some random questions later i hope you dont mind.
OldManZ350's Avatar
OldManZ350
Who would you Believe?
There is a Formula for calculating actual Gear Diameter. It's not the overall Diameter and its not the point where it makes belt contact…… it somewhere in-between…….
If Fliudamper says 6.25, then that is what I'd use…..It's always better to over estimate Blower speed, than under estimate it…..
Taken from 350z006
Old Nov 18, 2013 | 03:49 PM
  #38
Colombo's Avatar
The V1 and V7 have a different Strp up Ratio of 3.45/1 vs 3.61 of the V2 and V3
i did the calculator on vortechs site and got 54484.76 with the 2.87 at 7400 rpm.. not sure if i messed it up. its the last 1 on the page says v1/v7
im on 1k injectors and a CJM stage 2 with a walbro 400
Old Nov 18, 2013 | 03:53 PM
  #39
OldManZ350's Avatar
OldManZ350
The Calculator you used is without a Jackshaft, won;t work…..
You need the use the V2 with Jackshaft and subtract 4.2%.
PM me anytime……. or Email
Old Nov 18, 2013 | 04:03 PM
  #40
Triji's Avatar
Triji
Damn dude.... Sorry to see this... Hope you get her back up and in action soon...
I'll be tuning for the 2.87 and 3.12 but I think I'll be running the 3.12 more just to be on the 'safer' side of things.
Good luck man.
