Vortech gurus. Enter... 928m impeller. Shredded :-(
Old Nov 17, 2013 | 02:35 PM
Colombo's Avatar
Thumbs down Vortech gurus. Enter... 928m impeller. Shredded :-(
Yes it's only been 2k miles on my build/rebuilt blower w the 928m impeller 2 autoXs down and well over 150+ hard pulls and today at the end of my last run I heard a very scary noise and found this 👎👎 yes I am overspinning the blower to 7400 rpm. She made 608whp/446tq..My question is this bearing failure or something else?? Seem to have moved enough to shave itself down and does not spin free.i will be pulling blower and sending it back to 928m for a full inspection. Contacting them via email as we speak.
Old Nov 17, 2013 | 02:43 PM
freddys 350z's Avatar
freddys 350z
ouch! could the shaft be flexing under high rpm/boost?
Old Nov 17, 2013 | 02:51 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
shaft or bearing failure.
When my bearings failed (vortech manufacturing issue back in 2007-8 or so) that is what it did but on a much smaller scale. It was noisy as hell when it did it. I was on the way to a car meet and could hear it immediately. Pulled the belt off. My grinding was very minimal.
Old Nov 17, 2013 | 03:41 PM
Calinismo350z's Avatar
Calinismo350z
damn man sucks. hope you don't need a whole new unit. good luck..
Old Nov 17, 2013 | 03:55 PM
Colombo's Avatar
you and me both... if this is bearing failure i would assume it would be from overspinning? we will see what carl says.
Old Nov 17, 2013 | 04:25 PM
Calinismo350z
yeah. I think so far there's not a bearing capable of holding it. if Carl says it was that maybe your only option would be to upgrade the whole blower.
Old Nov 17, 2013 | 05:15 PM
OldManZ350's Avatar
OldManZ350
Hay Johnattan,
Sorry to hear about your Blower…..Looks like you have been Beating on that Blower pretty Hard. The V2 is a Street Blower.
You might want to Look at a fairly New Race Blower Vortech has out.
It's a V1 Ti Trim, rated at 1400cfm…. (The V1 has much larger bearing)
http://www.vortechsuperchargers.com/page.php?id=30004
Old Nov 17, 2013 | 05:17 PM
jomamahama's Avatar
jomamahama
stupid question, but where do the metal shavings end up?
Old Nov 17, 2013 | 05:20 PM
taywan's Avatar
taywan
Sorry to hear. It is always something. Hope you get her running good again soon GL.
Old Nov 17, 2013 | 05:32 PM
meanz's Avatar
meanz
Damn this sucks!
Old Nov 18, 2013 | 12:54 AM
KushZEN's Avatar
KushZEN
Randomly throwing this out there, and I don't know jack ****.... but... since you replaced the vortech bpv with a TialQ BOV. Would that cause anything like this at all?
Old Nov 18, 2013 | 01:53 AM
Colombo's Avatar
Tim thanks for the info will this blower bolt to my bracket? I will look further into it
Old Nov 18, 2013 | 01:55 AM
Colombo's Avatar
Kush I went w the tial Q after seeing the success the mustang community w much larger blowers were having w it. They make a special spring just for superchargers
Old Nov 18, 2013 | 05:07 AM
OldManZ350's Avatar
OldManZ350
Yes, V1, V2, V3 and V7 all have the same bolt pattern.
Old Nov 18, 2013 | 07:35 AM
djamps's Avatar
djamps
The shards/dust are ingested by the engine. I'd get leakdown compression test and spend some time with a boroscope before boosting again.
Old Nov 18, 2013 | 07:56 AM
rcdash's Avatar
rcdash
Intercooler should trap most of it I would think. If it's fine enough to travel through the IC, it would probably just go right out the exhaust port also... I would force water backwards through the IC to clean it out or swap out to a new IC if you see lot's of debris in there and don't think you can clean it. Don't forget to check the IC piping.
Old Nov 18, 2013 | 10:41 AM
the3kgt2's Avatar
the3kgt2
Sorry for your loss. It was a beast while it lasted.
I believe the 2.87 pulley with fluidampr crank pulley puts your blower at 65,156 rpm when revving to 7400rpm. No bearing could hold that.
You're also exceeding 928m's max rpm rating for the impeller too:
"Each impeller is spin balanced to 0.006 grams/inch, and designed to operate up to 60,000 rpm"
Old Nov 18, 2013 | 12:28 PM
Colombo's Avatar
What size is the fluidampr in inches? Also has anyone ran this v1 TI trim? 3k is a steep steep price to be a Guinee pig. Also would I not be overspinning that blower as well or is it capable of making this kind of power without such a small pulley. A lot if research I gotta do before I make any decisions last thing I wanna do is have it rebuilt and do this again.
Old Nov 18, 2013 | 12:58 PM
OldManZ350's Avatar
OldManZ350
You would not be a Guinee Pig…….
The Vortech V1(HD) Race Series Blower is Tuffer and Stronger the the V2(Std) Street Blower.
The V1 Ti-trim will push more Air (1400cfm) than your 928 impeller (1150cfm) at less RPM.
The WEAK part of your Build is the Blower……
You could go with the V7 YSi-Trim (1600cfm) A Super Tough Race Proven Blower.
I know guys that have made 26+PSI with No Belt Slip, when using My Radius Rod
Last edited by OldManZ350; Nov 18, 2013 at 07:09 PM. Reason: corrected PSI with no Slip
Old Nov 18, 2013 | 01:03 PM
jerryd87's Avatar
jerryd87
by there own words "almost" 1200 cfm at 50k vs the one old man posted of 1400 at 55k. its not like its some brand new start up company there isnt a "being a guinea pig" you should know not many people go super charger for big power. if you have questions its best to use google, just because it might be on a different car it will still perform the same way.
edit: old man posted while i was typing.
