Boost Leak?
Old Feb 8, 2014 | 06:04 AM
Jtrain's Avatar
Jtrain
Default Boost Leak?
All of the following is on an '04 G35 swapped to a CD009 6MT:
Hey guys,
Would love to pick everyones brain. I decided to stick with my G18s and just turn up the juice, but I think I've got a boost leak-- let me know if this makes sense.
Went from AT to MT with an HKS SSQV, there is no adjustment on an HKS (famously) but it was the only BoV I could really use with my AT and not stall at low RPM.... Now I was stalling at Low RPM when I moved to a MT.
We drilled a VERY small (3/16" ish) hole in my throttle body, and it cured my car diving for 300 RPMs everytime I hit the clutch (and ultimately stalling my car in a lot of situations).
So recently: I upgraded my wastegate springs, took the OLD HKS SSQV off and put a Tial 50MM with appropriate spring. I could only run about 16.5 PSI on the dyno and made 589 torque and about 575 HP ( No dyno sheet to show you)... Now when I drove it, the BoV sound was delayed by fluttering / surge.
I THINK, that hole in my TB is messing with my vacuum and boost at high boost, and now that my BoV has adjustability, I can use that instead of a hole in my TB.
Thoughts?
Old Feb 8, 2014 | 07:44 AM
Z_on_TE37's's Avatar
Z_on_TE37's
Mine flutters too, I also have a tial. And on my other car I have a blitz bov, also flutters. As long as it's holding boost when u go full throttle then it isn't a bad leak if any, try the old starting fluid trick to find the leak maybe ?
Old Feb 8, 2014 | 08:29 AM
Jtrain's Avatar
Jtrain
I'm really trying to figure out if I have one.
It seems strange that you change a wastegate spring to allow 20+ PSI and only gained 1.5 on the dyno.
amirite?
Old Feb 8, 2014 | 11:37 AM
rcdash's Avatar
rcdash
Too many variables to figure this out over the Internet. You should be able to push the 18Gs to 700 whp DJ.
Old Feb 8, 2014 | 11:44 AM
Jtrain's Avatar
Jtrain
Fair enough, I don't disagree... Just seeing if anyone had any ideas.
Old Feb 8, 2014 | 04:27 PM
Z_on_TE37's
Well 20+ psi will grenade your motor unless it's built to the guild
Twenty4
Jan 17, 2016 01:20 PM
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
