Walbro Fuel pump question
Old Apr 28, 2014 | 03:33 PM
Conway_160's Avatar
Conway_160
Default Walbro Fuel pump question
I did a few searches and found no information about a Walbro 416 pump.
http://www.full-race.com/store/fuel-...fuel-pump.html
Does any one have any experience with it? Would it be ok to run it on just pump gas until I have a built motor and tune it for E-85?
Only looking for 400-450 whp out of T-Trim V2 for now until motor is build and ready to go.
Old Apr 28, 2014 | 05:29 PM
phunk2's Avatar
phunk2
requires modification to the fuel sending unit to install it. requires return fuel conversion to get proper idle pressure. the stock sending unit will not allow the pump to reach its full potential. i have had a lot of customers ditch that setup and move to a twin pump just because the sending unit was holding the pump back too much.
Use an aeromotive 340 or AEM 50-1200... fits the sending unit better, and is a better match for it in terms of flow, and either will make over 500rwhp with E85 if the rest of your fuel system is up to the task, and assuming the non-replaceable filter in your sending unit isnt too backed up. either will probably still require a return fuel system, its unlikely the stock regulator is going to be able to do the job with these pumps.
Old Apr 28, 2014 | 11:50 PM
Conway_160's Avatar
Conway_160
Thanks Phunk I have a AAM FRS with 750CC injectors on their way, and I got a good deal on this pump "I think" if I wanted to get it.
Old Apr 29, 2014 | 05:25 AM
phunk2's Avatar
phunk2
i still think the aeromotive or AEM pumps are a better match for the stock fuel pump module... just because they actually fit without chopping it up, and their flow is more appropriate. make sure to run a relay and larger wiring for that pump... the factory wires will get really warm running it!
Old Apr 29, 2014 | 07:49 AM
Conway_160's Avatar
Conway_160
Thanks guys i'll skip on the 416 and get a walbro 255 or Aeromotive 340
Old Apr 29, 2014 | 08:12 AM
NissanZcrazy's Avatar
NissanZcrazy
So if you use an aeromotive 340 or aem 50-1200 you won't have to modify you stock sending unit,like with the walbro?
Old Apr 29, 2014 | 05:46 PM
midz350's Avatar
midz350
I have the DW300 pump, 1000cc injectors and a RFS installed for now. I bought the walbro 485 pump. Should I stick with the DW one or upgrade to the 485?
Old May 2, 2014 | 11:02 AM
phunk2's Avatar
phunk2
You will have to modify your sending unit very mildly, as if you were installing a Walbro 255. You will NOT have to modify it extensively, as if you were installing a Walbro 400/485.
Old May 2, 2014 | 11:03 AM
phunk2's Avatar
phunk2
If you arent losing fuel pressure on top, I would stick with what you have.
issyz
Jul 2, 2017 03:04 PM
