What gauges are you guys running?
Old Jun 17, 2014 | 08:31 AM
turboed350z's Avatar
turboed350z
Default What gauges are you guys running?
Just curious as to what selection of gauges my fellow FI guys are running.
My personally, I'm running fuel press, boost, and A/F ratio.
Old Jun 17, 2014 | 08:49 AM
iideadeyeii's Avatar
iideadeyeii
A/Fr only.
Old Jun 17, 2014 | 11:59 AM
Drako_MDx's Avatar
Drako_MDx
EBC (Boost/Vacuum)
AFR
Oil Pressure
EGT
And any other info I need off the OBDII on my LCD.
Old Jun 17, 2014 | 06:02 PM
Resmarted's Avatar
Resmarted
Boost, Oil Temp, Oil Pressure, AFR, AEM Failsafe watermeth (watermeth flow gauge)
Old Jun 18, 2014 | 12:26 PM
str8dum1's Avatar
str8dum1
primary Fuel pressure
surge tank fuel pressure
fuel pump speed
fuel pump voltage
scavange pump voltage
oil pressure
oil temp
boost
dual AFR
ethanol content
clutch pressure
radiator pressure
air temp
clutch slip
whp
wtrq
mostly on 1 sweet ProEFI color CAN logger display
Old Jun 18, 2014 | 08:35 PM
Resmarted's Avatar
Resmarted
fuel pump speed
fuel pump voltage
oil pressure
oil temp
boost
dual AFR
ethanol content
clutch pressure
radiator pressure
air temp
clutch slip
whp
wtrq
Lol. Money can do that for you :')
Old Jun 21, 2014 | 06:09 PM
Escobar's Avatar
Escobar
im just planning on running boost and AFR. Comes stock with oil pressure.
Old Jun 21, 2014 | 07:32 PM
Zivman's Avatar
Zivman
anything the ecu can see + a few others... boost, knock amp, oil temp, fuel pressure, water temp.
Using HKS Camp2 in on a display in my cubby. there is probably a pic around somewhere. IMHO, aesthetically much nicer than ProEFI display shown above
Old Jun 21, 2014 | 07:46 PM
Resmarted's Avatar
Resmarted
Stock Oil Pressure is pretty ball park, and oil temp is something I think anyone should run... on any aftermarket boosted car. Too high or too low, can cause premature wear or be a sign of serious problems.
A decent gauge with sender is like 100$, worth it.
Old Jun 23, 2014 | 04:36 AM
NA&CH's Avatar
NA&CH
+1.
I am running the Greddy Multi DA and AEM afr. One gauge but can display up to 7 different items. Boost, oil pressure, oil temp, fuel press, water temp, voltage, and egt. Also changes colors oooooaaaaa I have the Boost dial with oil temp and oil press. Plan on getting fuel press. All you need to buy is the sensor and hook it up to a little hub.
Chris
Old Jun 23, 2014 | 08:48 AM
94z28joe's Avatar
94z28joe
Boost and AFR
Old Jun 23, 2014 | 11:31 AM
eZg's Avatar
eZg
This thread got me wondering if folks are using a pc tablet to display info from a Haltech.
A quick google search only found a handful of threads in the Haltech forum but they were a couple years old. At that point the price was comparable to one of the Haltech RacePacks , whatever they call them. Now that tablets are cheap and you can get one with USB port wonder if that would work well......
Old Jun 23, 2014 | 04:26 PM
taywan's Avatar
taywan
Ya. Cheap ebay oil temp does the job....$20-$30 new. Works well.
Old Jun 24, 2014 | 09:53 AM
str8dum1's Avatar
str8dum1
i run a Carpc with a 7" touchscreen where the stock G35 nav was. Used that with my haltech. Now eveything is on my proefi display.
You'd have to buy a windows tablet, which are not very common or inexpensive compared to droid tabs. Mounting would also be cumbersome.
Old Jun 24, 2014 | 10:04 AM
eZg's Avatar
eZg
Yup....Hal returned my email this morning saying that you need a tablet that runs windows.
Found this one on amazon 7" $200
Amazon.com : Toshiba Encore WT8-A32 8-Inch 32 GB Tablet : Tablet Computers : Computers & Accessories Amazon.com : Toshiba Encore WT8-A32 8-Inch 32 GB Tablet : Tablet Computers : Computers & Accessories
can you elaborate on differences between Pro EFI display and the PC you were using?
Thank you
Old Jun 24, 2014 | 02:46 PM
Resmarted's Avatar
Resmarted
Thank you
PC would have to boot up everytime you start the car, then load the ecu manager and connect. I know you can set ecumanager to autostart, but I'm not sure how streamlined you can make the whole process, and on a cheap windows tablet you're not going to get 'lighting fast' startups. IMHO i'd just get some gauges you like for the money.
Pro EFI I'm sure will be really well sorted and fast
Old Jun 24, 2014 | 03:13 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
You see my thread about wireless connection to haltech over USB? Went to my samsung tablet runnings windows 7. Solid state.
To the other guy, carpc power supplies are set up so that the pc stays on unitl battery voltage drops below a user defined level. Also with ssd boot time is nothing. You could have it booted in the time that you warm up the car.
Old Jun 24, 2014 | 03:20 PM
Resmarted's Avatar
Resmarted
I always wondered about the power supply. Good to know
Old Jun 27, 2014 | 05:01 PM
str8dum1's Avatar
str8dum1
this is what I use. http://store.mp3car.com/M3_ATX_125_W...-xcv4-0ygm.htm
I also have a SSD harddrive.
apex locator
Jul 23, 2021 02:27 AM
35reilly
Sep 28, 2015 07:42 AM
