TurboXS UTEC Map Sensor Question
Old Dec 9, 2014 | 09:38 AM
Cblast's Avatar
Cblast
Default TurboXS UTEC Map Sensor Question
Can I hook up a 3 bar GM Map Sensor to the UTEC?
I have the 3 wire pigtail but the Map Sensor input on the UTEC is a 4 pin plug.
Can't find any instructions in the UTEC manual and when I called they said they haven't used in 6 years so don't know.
Old Dec 9, 2014 | 03:54 PM
str8dum1's Avatar
str8dum1
as far as I remember, there is no way to tell the UTEC what range the map sensor is, so I'm pretty sure you need to use theirs
Old Dec 17, 2014 | 09:25 AM
andybp's Avatar
andybp
yes you can use another map sensor only three wires are used on the utec sensor +5v
0V and the output and you can calibrate it against a accurate pressure gauge if you have one
Old Oct 7, 2015 | 02:53 AM
DMM's Avatar
DMM
Good day! I have a utec and would like to connect a map sensor from another manufacturer. But in my map is three wire, and 4 utec connector! Does anyone have a Pinout utec map?? Sorry for my English
2ndchanceZ
Oct 26, 2015 08:03 PM
