New power 577whp **Ahdal 350z**
Old Jan 19, 2015 | 01:00 PM
Conway_160's Avatar
Conway_160
Well crap, that's double my injector and pump. Looks like I'm going to have to upgrade my injectors and pump to be safe. How is your idle with injectors that big?
Old Jan 19, 2015 | 01:02 PM
aboodi's Avatar
aboodi
Originally Posted by OldManZ350
I'm a lot bigger than you are.
If you bigger than me mr.tim it does not mean you are 500 pounds.. Haha..
Old Jan 19, 2015 | 01:03 PM
aboodi's Avatar
aboodi
See the video.. Its super smooth daily car with standalone too
Old Jan 19, 2015 | 01:06 PM
Conway_160's Avatar
Conway_160
I'm running uprev i wonder if it will be harder to get it to idle.
Old Jan 19, 2015 | 01:08 PM
Colombo's Avatar
Thanks man
Easy.. Go 34 28 cogs.. 2.87 v belt.. Must buy timrod structrod.. He is here just send him a message now.
Abdullah this is jfranco I have his brace haha I'm just not adding up to 17/18psi w just a 32/28 cog swap ESP at only 7000rpm.i would love to see you spin that blower to 7500rpm... I was making 14psi with stock cogs and a 2.87 revving to 7200rpm when I was stock block. And I know some have even ran the 2.62 w stock cogs and only saw maybe 16psi. I didn't even think the sci trim was capable of 17/18 psi. I mean I made 18psi with a 928m impeller spinning to 7600rpm and 65k impeller speed with tims brace. Regardless that's crazy impressive. Job well done!
Old Jan 19, 2015 | 01:23 PM
OldManZ350's Avatar
OldManZ350
I'm running a 34/28 cog with a 2.87 serp @ 7100 I'm 18psi.
For the Dragstrip I use a Bellmouth Velocity Stack on the intake of the blower. It adds considerable Air Flow to the blower and will increase boost.
Old Jan 19, 2015 | 01:29 PM
OldManZ350's Avatar
OldManZ350
Injector Size has nothing to do with Idle, it has to do with the quality of the Tune.
Injector Size has nothing to do with Safety. It has to do with suppling the right amount of fuel. And that requires the elements of the whole Fuel System.
If you have a piggyback that can't compensate for larger injectors, then that is the weak link in the chain.
Old Jan 19, 2015 | 01:50 PM
aboodi's Avatar
aboodi
hey bro... how are you doing.
thanks for the comment,,
sure i will rev it to 7500.. but ecu need reflash... i use standalone and the stupid stock ecu try to interrupt the standalone..
dont worry.. i will be happy with this number for couple weeks then go crazy more
Old Jan 19, 2015 | 01:54 PM
aboodi's Avatar
aboodi
i gained from that bellmouth only 1 psi.. but i have bigger cams,, maybe that why i get lower psi.. maybe i have small boost leak.. but i will relax for couple weeks then make more power
Old Jan 19, 2015 | 01:58 PM
OldManZ350's Avatar
OldManZ350
Oh Ya, that's Right you have a RevUp......
That's why you are making as much Hp as me.... haha
You have a 15chp advantage right from the start.
Old Jan 19, 2015 | 02:00 PM
OldManZ350's Avatar
OldManZ350
The Bellmouth adds Air Flow and HP, forget about Boost numbers, focus on Hp.
Old Jan 19, 2015 | 02:01 PM
OldManZ350's Avatar
OldManZ350
How much does it cost you, every time you get on that Dyno?
Old Jan 19, 2015 | 03:39 PM
aboodi's Avatar
aboodi
80$..
today i gave him 100$.. i spent a lot..
Old Jan 19, 2015 | 03:41 PM
aboodi's Avatar
aboodi
buy the gears that you told? i called them,, they said its not gonna give you hp numbers and torque in good way for tuning.. he said on road many variable things.. the dyno controlled environment..
Old Jan 19, 2015 | 04:06 PM
NAbuilderZ33's Avatar
NAbuilderZ33
Hmm, im gonna try that out for my blower!
Old Jan 19, 2015 | 05:05 PM
OldManZ350's Avatar
OldManZ350
Just keep in mind, it's for the Track, not for the Street, because of no air filter.
Old Jan 19, 2015 | 07:10 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Congrats!
Old Jan 20, 2015 | 02:40 AM
  #38
aboodi's Avatar
aboodi
Congrats!
Thanks man
Old Jan 20, 2015 | 09:54 AM
  #39
JERZ350's Avatar
JERZ350
Awesome job man - unbelievable on stock internal, keep the pulls smooth and conservative if you can. Hoping for long life!
Old Jan 22, 2015 | 05:23 AM
  #40
aboodi's Avatar
aboodi
Thank man,,
its gonna be long life.. TimRod made 40k miles on his boosted z.. 60 runs on the drags .. hundred of pulls on the streets..
its all about how you do it right..
faulty work will break forged engines..
