Starter question for a Supercharged Z
Old May 30, 2015 | 01:53 PM
NeoGixxer's Avatar
NeoGixxer
Default Starter question for a Supercharged Z
First off I appreciate everyone's help on here. With your help I was able to install a SC and fix all the issues that came with it.
Currently I'm experiencing some starting issues. On a cold start, she cranks and turns over no problem.
If I ran her for about 30-45 mins, turn her off wait about 8 to 12 hours and try to start her again, I will have issues. She will crank and crank and crank and then will finally turn over with my belts squeaking for a couple secs.
But if I run her for about 5 mins, shut her off and start it again. She will turn over no problem.
So I don't waste any money on parts. Should I assume its just the starter? maybe a tune problem that needs to be tweeted? Has anyone experienced this with a Supercharged Z?
Old May 30, 2015 | 03:19 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what injectors and EMS?
Old May 30, 2015 | 03:55 PM
Conway_160's Avatar
Conway_160
If the motor is spinning every time you turn your key its not your starter. If the motor isnt spinning then its battery more then likely. It sounds like its in the tune though sounds kinda like you need to mess with cranking enrichments.
Old May 30, 2015 | 07:50 PM
- bigc -'s Avatar
- bigc -
Based on your previous posts it looks like you're using Uprev for engine management, have upgraded your injectors, and have Church do your tuning. If so, tell Church you're having hot start issues. If you search for 'hot starts' on here you'll see a bunch of threads on this topic. As said above, they'll need to tweak your tune a bit to fix the issue.
Old Jun 2, 2015 | 07:53 PM
NeoGixxer's Avatar
NeoGixxer
Greta, thank u guys
Old Jun 3, 2015 | 09:23 PM
- bigc -'s Avatar
- bigc -
You're welcome. And don't call me Greta.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
