Fuel Pressure
Old Jun 18, 2016 | 07:53 AM
Conway_160's Avatar
Conway_160
Default Fuel Pressure
So I've been looking and can't find an answer. Is it necessary to have your fuel pressure increase with your boost? At 51psi w/ my 750's that is more than enough fuel for my procharger, is it really necessary for fuel pressure to raise since I will only be hitting 13-14psi of boost?
I know that raising the fuel pressure should help keep the duty cycle down but I wont even be close to maxing out my injectors.
Old Jul 8, 2016 | 05:09 AM
str8dum1's Avatar
str8dum1
does your ecu have fuel pressure compensation? if not, you will run lean. injector pulse width of 1.2ms at 50psi is alot more fuel than 1.2ms at 51psi minus whatever boost you are running
Old Jul 8, 2016 | 06:04 AM
Conway_160's Avatar
Conway_160
Im running a haltech redbox so im not 100% sure i haven't really looked at all the screens.
Old Jul 17, 2016 | 04:27 PM
Conway_160's Avatar
Conway_160
Ok so im messing more with this haltech. I have a flow rate table that has -29.2 psi, 0 psi, and 33psi. If i set them all at 755. Static flow of my injectors can i leave my fuel pressure at a static 43.5psi?
Old Jul 18, 2016 | 10:05 AM
phunk2's Avatar
phunk2
Fuel pressure profile just needs to stay the same as it was when the car was tuned. If you havent tuned yet, then its all up to you how to set the fuel pressure first.
Old Jul 18, 2016 | 10:58 AM
Conway_160's Avatar
Conway_160
Ok it hasnt been tuned yet.
Old Jul 18, 2016 | 11:09 AM
phunk2's Avatar
phunk2
In that case, you just need to make sure that under full boost, that your fuel pressure differential will be high enough to get the fuel you need. Because if you run out when you get up there, you get to start your fuel tuning over almost from scratch depending on the EMS.
timmays350
Jul 8, 2016 06:02 AM
Zivman
Jun 17, 2016 02:17 PM
Musashi_ha
Jun 11, 2016 08:45 AM
turboed350z
Jun 3, 2016 05:54 PM
timmays350
Tuning
May 25, 2016 05:03 PM
