Built engine, 50 miles on kit and blown engine?
Old Sep 18, 2016 | 02:07 PM
bealljk's Avatar
bealljk
Originally Posted by Speednz
That would be an awesome alternative since a set of cams for these cars are outrageously priced for a slightly raised lobe.
These will carry a premium based on availability...if it was me, I'd run your DE cams until you get your headwork done ... but I wouldnt fault you if you could pickup a quality set of rev-up cams or aftermarket cams.
Speednz - I would also apply multiple coat of the copper-spray gasket on the head gaskets...not sure if you were planning on doing this.
if your block has the machined water-jacket modification and your generic head gaskets did not have this area notched out it may have led to the excessive coolant temps and ultimately the failure of the block...
ThatZGuy
Sep 13, 2016 09:20 PM
Dartys zz
Sep 11, 2016 02:42 PM
theGentlemenZ
Sep 11, 2016 12:32 PM
VO...
Sep 4, 2016 09:40 PM
