Single Turbo Oil Pressure
Old May 19, 2017 | 05:51 AM
algy's Avatar
algy
Default Single Turbo Oil Pressure
Just curious what the oil pressure should be at for our VQ35 engines? My 2006 single turbo nonrevup DE is sitting at roughly 18-20. At start up its at 60-70 and cruising its at 30-45.
Why does that seem low to me? Possibly it could be the oil weight i am using? If so what is everyone using on their forced induction VQ35DE? I have roughly 110k miles on the vehicle if that helps and live in Dallas Texas
Old May 19, 2017 | 06:40 AM
iideadeyeii's Avatar
iideadeyeii
That seems right. I'll check mine when I get home if I remember.
Old May 19, 2017 | 06:42 AM
algy's Avatar
algy
Really?? For some reason I thought that was low. What oil are you using and weight?
Old May 19, 2017 | 06:58 AM
iideadeyeii
Cheap full synthetic 10-30
Old May 19, 2017 | 07:00 AM
iideadeyeii
I think I'm using castrol full synthetic 10-30, but really I'll use any cheap full synthetic.
Fram tough guard filter iirc
rancor's Avatar
rancor
For all the stock engines with 5W-30 it is >14psi at idle (650 rpm) and >43psi at 2000 rpm in neutral or park.
Old May 19, 2017 | 10:19 AM
algy's Avatar
algy
So what if the engine is not stock? As in turbos, supercharger, etc. Nothing like a built motor though.
Old May 19, 2017 | 12:42 PM
rancor's Avatar
rancor
As long as the bearing clearances are stock thoes should be the recommended numbers. Oil cooler shouldn't really change the pressure. It would probably increase it slightly if the cooler is before the sensor. As long as the piping to the turbo(s) is restricted enough it shouldn't be stealing too much flow to drop the oil pressure.
Old May 27, 2017 | 02:42 PM
algy's Avatar
algy
Also what oil do you guys recommend? Texas weather and 113k miles on the vehicle
