Removing transmission with greddy twin turbo setup
Old Jul 4, 2017 | 05:07 PM
bigcjohnson2003's Avatar
bigcjohnson2003
Default Removing transmission with greddy twin turbo setup
Has anyone ever removed your transmission without removing the wastegates? I need to replace my clutch and I was wondering if I do this without removing my wastegates will the transmission come out? I have a 06 350z with 6 speed.
Old Jul 4, 2017 | 08:11 PM
bealljk's Avatar
bealljk
nope...gotta take the waste gates off or take the engine out with the transmission...once you get everything out consider adding a waste gate relocation kit.
Sucker Punch Motorsports has a kit that's not too expensive...
Old Jul 4, 2017 | 11:34 PM
bigcjohnson2003
Thanks man that is what I was thinking but just checking to see if there was something I was overlooking.
Old Jul 9, 2017 | 03:56 PM
TT03Z's Avatar
TT03Z
Even with the wastegate relocation kit I had to remove the passenger side wastegate tube to get my transmission out when I did my clutch. At first I thought it would clear then ended up having to put the tranny back in and take the gate off. It was in general a pretty easy clutch job compared to some other vehicles.
Old Aug 2, 2017 | 07:53 PM
SAMzG35's Avatar
SAMzG35
Mine just went as well I think I'll be removing the engine & transmission.
Old Aug 2, 2017 | 08:34 PM
bealljk's Avatar
bealljk
^yea, it's really not that much more work and a good opportunity to change trans fluid and inspect wires/sensors/etc.
Be deathly careful not to knick-up your driveshaft!
Old Aug 2, 2017 | 08:58 PM
SAMzG35's Avatar
SAMzG35
I did it before when I installed my TT setup.
Now I'm installing a built motor and a upgrading my clutch.
